Anyone ever run a wood splitter off a 755?
   / Anyone ever run a wood splitter off a 755? #1
unimog_jason
New Brunswick, Canada
JD 755, Kioti DK40SE, JD 410
I need to pick up a wood splitter and it would be nice to run it off my tractor but I'm not sure if the little hydraulic pump would put out enough flow to make it worth while.
According to tractordata.com the pump is rated for 5.6GPM and I assume that is when the engine is running wide open.
Off the cuff I would think running a 20 ton splitter off this machine would be pretty slow but thought I'd check and see if anyone has done it before I start looking for alternate solutions.
Jason
   / Anyone ever run a wood splitter off a 755? #2
Get a stand-alone splitter. You can tow it with your tractor and then still use your tractor to move logs, rounds, split wood, etc without disturbing the splitter set-up.
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2006 INGERSOLL RAND AIR COMPRESSOR (A52472)
2006 INGERSOLL...
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
