Anyone ever run a wood splitter off a 755?
   / Anyone ever run a wood splitter off a 755? #1
unimog_jason
New Brunswick, Canada
JD 755, Kioti DK40SE, JD 410
I need to pick up a wood splitter and it would be nice to run it off my tractor but I'm not sure if the little hydraulic pump would put out enough flow to make it worth while.
According to tractordata.com the pump is rated for 5.6GPM and I assume that is when the engine is running wide open.
Off the cuff I would think running a 20 ton splitter off this machine would be pretty slow but thought I'd check and see if anyone has done it before I start looking for alternate solutions.
Jason
   / Anyone ever run a wood splitter off a 755? #2
Get a stand-alone splitter. You can tow it with your tractor and then still use your tractor to move logs, rounds, split wood, etc without disturbing the splitter set-up.
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
ASSET DESCRIPTIONS & CONDITION (A52577)
ASSET DESCRIPTIONS...
Yamaha Golf Cart (AS IS) (A50774)
Yamaha Golf Cart...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
