Anyone ever hear of this Power Pack?
   / Anyone ever hear of this Power Pack? #1
Hunterofbc
Chilliwack BC
Kubota
I'm looking for any info you might know about this:
It says Vickers Hydraulic Power Pack. Model number PK1 1100 D 12.
The tag also has a 74 stamped in the top left corner.
Also has a bunch of patten numbers but that's it. Thanks for looking.
Mitch
   / Anyone ever hear of this Power Pack? #2
:welcome:
   / Anyone ever hear of this Power Pack? #3
Any pictures?
   / Anyone ever hear of this Power Pack? #5
Mitch
I think these are semi obsolete. I am going to try and attach a data sheet on them.
  • i3006s.pdf
Thank you very much for the help. It sure is the info I needed, exept the GPM. Thanks again Mitch
   / Anyone ever hear of this Power Pack? #7
Based on the model code of PK1 1 1 0 0 I would say 1 GPM at 1200 RPM since Vickers vane pumps where rated in GPM flow nominal at 1200 RPM.
PK1 = long tank
1 = 1 GPM at 1200 RPM
1 = single acting valve
0 0 = no other valves
D = relief ste at 1000 PSI
12 = design series
Suspect right hand rotation (CW) since the Left hand was optional and is not noted in the model code you provided.
   / Anyone ever hear of this Power Pack? #8
I cleaned out of building and this was in with the stuff that I had to leave I know nothing about it but it's similar to what you have
   / Anyone ever hear of this Power Pack? #9
Welcome to TBN.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
