Rear Blade Anyone ever convert a 3 bottom plow to a two bottom?
   / Anyone ever convert a 3 bottom plow to a two bottom? #1
longjohn79
PA
JD2010
I was at the scrap yard this morning and a fella was throwing out a 3 bottom plow. Upper arms need refab'd as they are bent and stabilizer arms are broke up to the top link connection. But the plows are in good shape. It's a heavy set. Too heavy for my L-35 but I grabbed em anyway. Thought about taking one plow off, anyone ever do that? If it doesn't work I will just fix and sell or trade them. IMG_2581.JPG
   / Anyone ever convert a 3 bottom plow to a two bottom? #2
Plowing is an advanced Three Point Hitch skill.
I doubt you can rehab that mangled plow so that it will function satisfactorily. "Close" does not usually provide satisfactory service.
Actually other than the top arms that come up for top link and the corner of that mold board it's all straight. The front plow is just tripped.
   / Anyone ever convert a 3 bottom plow to a two bottom? #4
Yes you can remove the rear section and have it function as a two bottom
That's what I was thinking, thank you LD1! I got the plow to reset and now I'm searching for scrap to make the upper arms from.
2012 PETERBILT 367 WINCH TRUCK (A55745)
2012 PETERBILT 367...
2015 Ford Fusion S Sedan (A55853)
2015 Ford Fusion S...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
