anyone ever closed off the side discharge chute on a finish mower?
   / anyone ever closed off the side discharge chute on a finish mower? #1
kossetx
Platinum Member
TX
NH TC 40 A, AC 5020
To make it mulch? Just wondering...
   / anyone ever closed off the side discharge chute on a finish mower? #2
I have gator blades on my finish mower and it does a great job. I actually bungee the side discharge guard up so it can spread better. I never rake leaves or grass anymore.
   / anyone ever closed off the side discharge chute on a finish mower? #3
Try gator blades and don't let the grass get to high before you mow........
   / anyone ever closed off the side discharge chute on a finish mower? #4
I got a 7' rear discharge mower and still get a slight row of grass on the right side. I think your grass would still bunch up with a shield on. Unless you want to put a shield on so grass don't shoot against something.
   / anyone ever closed off the side discharge chute on a finish mower? #5
I think it depends on how your baffles under the deck are spaced. For instance, my craftsman mower just has a straight open channel between the 3 blades. Installing mulching blades and blocking off the chute turns it into a great mulcher.
My massey deck on the other hand, first off I can't even find mulching blades to fit it. But even if I did, the deck design has a "bay" for each blade, and all three open up to a channel which then directs the clippings out the chute. Just blocking the chute would turn the clippings into a clumped-up mess in there. Kubota has a similar deck design, but they actually have a kit you could buy which converts the deck into a mulcher. It involves blocking off that channel I'm talking about.
   / anyone ever closed off the side discharge chute on a finish mower? #6
I run a chute blocker on my ZD mowers, with gator blades and a non - mulching deck. It's not a solution for regular and constant mulching, as it leaves a windrow.
I block the chute mostly to avoid splattering flower beds etc, or for finely pulverizing leaves in the fall.
   / anyone ever closed off the side discharge chute on a finish mower? #7
Not sure why but the mfg of gator blades says not to use them with a mulching blank installed.
   / anyone ever closed off the side discharge chute on a finish mower? #8
I have a 1991 Farm King 72" mower. I completely closed off the side discharge and opened up the whole rear to make it into a rear discharge mower. There is no "tunnel" for the grass so that isn't an issue. I need to add baffles under the deck the same as a factory rear discharge mower has. Other than not distributing the grass evenly it is an excellent modification. It really upped my mowing speeds in similar conditions.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A52472)
2015 DRAGON 137BBL...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
198367 (A51243)
198367 (A51243)
