Anyone else see the article about the new Yanmar Outboard?
   / Anyone else see the article about the new Yanmar Outboard? #1
clemsonfor
Super Member
Greenwood Co., SC
Yanmar YM2000
I will try to link to it tomorrow but the other day I read an article about yanmar anouncing it will produce a turbo diesel outboard. I think it was a 50hp. It will use way less fuel than comparable outboards and have twice the life. It will be a 2 cyl and have twin crankshafts and 2 connecting rods per piston, giving it a very smooth operation they said.
   / Anyone else see the article about the new Yanmar Outboard? #3
Maybe like the RR K61. It could have 2 x Opposed pistons per cylinder. Effectively a 4-cyl engine. 2-stroke ported. No cylinder heads. No valves. Diesel, so no need for spark plugs.
Looking forward to the link.
   / Anyone else see the article about the new Yanmar Outboard? #5
Thanks Rocky. That wasn't at all what I was expecting. Pretty interesting indeed. :cool:
   / Anyone else see the article about the new Yanmar Outboard? #6
The link shows on here as 5HP, but the article is clearly the 50HP beast.
   / Anyone else see the article about the new Yanmar Outboard? #7
Woot!!!!
I can use Off Road Diesel and still be compliant!
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
Ford Pickup Truck Bed (A49461)
Ford Pickup Truck...
71061 (A49346)
71061 (A49346)
