Anyone DIY dye their hydro oil?
   / Anyone DIY dye their hydro oil?
A flashlight might make the level on a dipstick easier to see. Might also work for a sight glass
For sure, I sometimes use the one on my phone. But it's a pita with dirty hands while holding a dipstick.
I wonder why they don't just dye the damn stuff at the factory, like ATF! It's so clear it's really hard to see.
   / Anyone DIY dye their hydro oil? #12
JD hyd oil dye is part # MT3668
   / Anyone DIY dye their hydro oil? #13
I bought some on line, it doesn't take much. My hydraulic guy tells me ATF is just hydraulic oil with dye in it.
(y)
In that they're both types of hydraulic oil, sure. But you wouldn't want to run regular hydraulic oil in an automatic transmission. ATF has a compound viscosity designed to vary less with temperature than conventional hydraulic oil, friction modifiers, as well as some detergents.
   / Anyone DIY dye their hydro oil? #16
Mines tax-free even before the dye ... Ag exemption!
You are lucky in MO., In TN. all oil is taxable no matter if it is for tractor or not. They say you could use it in vehicles or mowers. I am Ag exempt also but doesn't help with the purchasing any oil
   / Anyone DIY dye their hydro oil? #19
Instead of spending money on dye, maybe simply put it towards new glasses? 🤷‍♂️
   / Anyone DIY dye their hydro oil? #20
Have been using the JD dye in my Kubota's for years,didn't turn them "green".Just kidding!
Make sure to tell your mechanic,they thought I had put trans fluid in.
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A56129)
2020 VANGUARD CIMC...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2004 FREIGHTLINER FLD112 TANDEM AXLE REAR DISCHARGE CONCRETE TRUCK (A56129)
2004 FREIGHTLINER...
