Anyone converted a Kubota Tractor to CNG?
   / Anyone converted a Kubota Tractor to CNG? #1
jrboss
Kubota B2100 HSD
I'm thinking about converting my Kubota B2100 to run on CNG ... looking for advice on converting the current diesel or installing a new one, and just general thoughts. Am I nuts? ...or is this something worth doing?
   / Anyone converted a Kubota Tractor to CNG? #2
For the value to your tractor i wouldn't. You could look at the ZD332 to see how they did that to LP.
   / Anyone converted a Kubota Tractor to CNG? #3
you better get a gas Fergie, MH or whatever tractor and experiment with that. I agree, its a waste of your tractor.
   / Anyone converted a Kubota Tractor to CNG? #4
There is no positve benefit to using CNG vs diesel for a small tractor. First of all, where are you going to fll your tractor tank with compressed natural gas? You cant have it delivered like LPG. Maybe that is what you meant rather than CNG. LPG is cheaper than diesel per gallon, but it takes sooooo much more of it to produce the same power. NO WAY would I convert a diesel to LPG or CNG or any other fuel.
   / Anyone converted a Kubota Tractor to CNG? #5
How about if you had a natural gas well and were looking into getting a compressor and converting your road vehicles and thought that it might make sense to convert you tractor as well?
   / Anyone converted a Kubota Tractor to CNG? #6
You couldnt compress enough natural gas to get you away from the wellhead more than a few feet and you would need a very expensive compressor to do it with. Maybe if you had a free source of liquified natural gas it could be beneficial but you would have to burn a lot of it to ever break even on the conversion. You might could use a LPG gas injection system into the diesel engine to get more power, but then there are easier ways to get power from a diesel like turbo-chargers and intercoolers which would do the same thing for less money and lots less hassle with filling extra tanks.
   / Anyone converted a Kubota Tractor to CNG? #7
The compressor runs about 20 grand for a home unit with a storage tank, a little less if you want to pump directly to the tank in the vehicle. The tech I talked to said something in the 100 mile range for a typical Honda sedan setup and I personally can attest that a filled tank can run a forklift 6 to 8 hours straight of intense freight moving. Those are gasoline engines but I have talked to a diesel engineer and he tells me that they can absolutely be run on cng but he didn't know what kind of fuel usage to expect because it wasn't his area.
Now if I am getting the stuff out of the ground and compressing it already and my tractor can be set up to run for say 4 hours on it then I don't see why I wouldn't do it.
Then you can consider the setups like they do with propane injection and you could just cut your diesel use way back.
The biggest problem with it would be that the high pressure tanks are about twice the size of a typical forklift propane tank and it would be hard to find a good spot for one on a typical compact tractor, or even larger tractors for that matter.
   / Anyone converted a Kubota Tractor to CNG? #8
Nuts.
   / Anyone converted a Kubota Tractor to CNG? #9
Good Luck
   / Anyone converted a Kubota Tractor to CNG? #10
you want a spark plug engine to convert, and the conversion would be similar to doing a propane unit but the regulators would most likely be different,
when I converted my generator (6 cylinder Chrysler industrial engine) I used a fork lift conversion kit for LP, it was an add on carburetor, that attached in front of the gas carburetor, and then there was a vaporizer and regulator and of course the tank. it can still run on gasoline if needed,
but on diesel there did some duel fuel that used both LP and diesel at the same time by adding some LP and injecting it to the air stream it would either produce more power or reduce the diesel used, this is just an example, Propane Injection Systems fuel savings in Diesel, Gasoline Turbocharged Engine Trucks, water vapor air fuel system separators
diesel PROPANE INJECTION - Google Search
I would guess one could do the same with CNG Natruell CNG Conversion Kit - Diesel Engines - Diesel Power Magazine
diesel cng INJECTION - Google Search
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
20306 (A51694)
20306 (A51694)
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
