LostInTheWoods
Platinum Member
Problem: Bx2660 will not start.
Back History: After rotary cutting for about 2 hours, I drove the tractor back to the driveway. I hopped off to do something without thinking, and did not engage the parking brake. Kill switch did it's thing, and engine shut off.
I hopped back on to start her up, but she wouldn't crank. All the usual lights come up on the dash, and you can hear the "click-click-click" when I turn the key. But she doesn't even begin to fire.
I played with the kill switch, made sure nothing was engaged (i.e. PTO), checked battery terminal cleanliness. All good. I hate to bypass the kill switch if there's something else I might be missing (I do a lot of work on hills). Haven't tested the battery, but it's barely more than two years old and had cranked the engine no problem prior to this.
Elsewhere on TBN, there's a thread about the B models having a similar problem not firing although you could hear the solenoid click. Their problem seems to have been remedied by putting a low voltage regulator ("John Deere part AM107421") in line. Any BX's have this issue?
What else should I run through before digging out the wire cutters?
Thanks,
Lost
Thanks,
Lost
