Anyone add a side step to their Yanmar?
   / Anyone add a side step to their Yanmar? #1
doctorwho00
Lynchburg, TN
Yanmar 2620D
Just curious if anyone has added a step to their Yanmar? I've thought about making one just to help me get on and off a little bit more easily. I've got a YM2620D, and it's not a huge tractor by any means, but it is a fairly good step up to get on it. This is particularly true if my boots are wet, and I've noticed I put a lot of pressure on the sheet metal where I step which isn't all that sturdy. Just curious if anyone has added one to their tractor.
   / Anyone add a side step to their Yanmar? #2
My tractor is not a large of one as you have and I needed a step up, Or more of a step down, having some way of manuvering and placing my foot climbing aboard or step down, I can only use the side opposite the loader control, I utilized the FEL tower on this side by welding on a U shape bracket with teeth cut into the top side so's the edge of my foot won't slip off,
   / Anyone add a side step to their Yanmar? #3
I would really like to have a step also. New Holland offers an optional step kit for nearly $300 which is ridiculous! I'll be standing by to see if you come up with something effective and affordable. Good luck.
   / Anyone add a side step to their Yanmar? #5
I though all yanmars had a step.I have 1 that is like a ring step that hangs from the bottom of the platform
Man you guys with the fancy new model tractors with all the doodads. :)
I made this from a surplus switch panel.
   / Anyone add a side step to their Yanmar? #6
California, I'm sure this give you a good size step,:thumbsup: Have you ever considered installing larger foot-boards? It can be done, Not only does it provide more foot room it helps to prevent things from coming up onto the foot-boards from the ground,;)
Story: Once back when I had my Kubota and working in clearing the badly covered underbrush and vines on our property the tires picked up a vine wrapped around the axle and happen to wrap around my foot and the foot-board, luckily my foot was resting on the clutch peddle and when the vine tighten it pulled the clutch in stopping the tractor, I put the tractor in reverse to try release the tension enough that I might pull up my foot, but could not, so I shut down the tractor got out my ol-pocket knife and cut the vine away, This along with the size 12 foot was one of the reasons when I got the Yanmar I needed to build and change out to larger foot-boards, They are now from against the axle and go 2" closer to the clutch and brake peddles, I also made them wider from against trans housing and notched them around the fenders, In other words there are no gaps left anywhere at the foot-boards for anything to get up through, it was an easy conversion, and still looks factory from using diamond plated metal,;)
Thanks for all the ideas guys!
   / Anyone add a side step to their Yanmar? #8
Have you ever considered installing larger foot-boards? It can be done, Not only does it provide more foot room it helps to prevent things from coming up onto the foot-boards from the ground)
I never thought of making larger footboards but you're right, the way they are attached it would be easy to make replacements.
For that YM240 with oversize tires, I just needed an 'old man step' when I was watering new trees and was climbing on/off continually with muddy boots.
The little YM186D could really use broader footboards. The existing ones are so tiny that there is no space to rotate your foot (the way a stirrup swivels) when mounting and particularly dismounting.
That's a scary story about the vines that you had to cut to get free of!
   / Anyone add a side step to their Yanmar? #9
I added a 3/8 plate to the front end loader back post. it is 8x8 and works good. L. J.
   / Anyone add a side step to their Yanmar? #10
Check out the factory side step on this ym240 from 1976.
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
1997 Equipment Trailer, Dual Tandem Axles (A52384)
1997 Equipment...
2025 JMR 36in Bucket Skid Steer Attachment (A51691)
2025 JMR 36in...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
