Anybody try the newer R14 tires?
   / Anybody try the newer R14 tires? #11
You need to take into consideration that the R14T's are radial tires and the R4's are most likely bias.
The ballooning is evident, 12, 06, 03, and 09 O'clock, loaded or unloaded.
SDT
   / Anybody try the newer R14 tires? #12
   / Anybody try the newer R14 tires? #13
I have r14t tires on my new m7060 with 140 hrs and I love them. The tractor came standard with a 6 ft bucket and the dealer upgraded to a 7 ft at my request. The tires do balloon some with the bucket full but not to the point that I would reconsider getting something else. My opinion of which tire to buy is this: Traction R1-Loader R4-Turf R3 but if you are looking for the tire that comes at number 2 in each of these categories then R14 is it plus they ride very smooth on the road. I bought a hd one shank subsoiler rated for minimum of 40 hp and and I need all 70 horses to pull it in my hard clay soil but no problem as far tire traction. I am considering purchasing a 3 cu yd dirt pan, if the tractor can handle it, I know the tires can
Any pictures of tractor so we can see how those tires look? I saw some on a JD 5000 series and they sure looked impressive.
   / Anybody try the newer R14 tires? #14
On clean turf, with a short test, it shouldn't be surprising that a turf tire has the best traction. But it's not all about traction, and especially not only on firm short turf. You should consider your own intended use. How do these tires perform when in long pulls through soft soil, mud, snow, up inclines. How will the tread load with dirt/snow and lose traction after a few minutes. What about ride comfort if that's important to you, and road use etc. Lots to consider and no single correct answer.
   / Anybody try the newer R14 tires? #15
I was more worried of bulging side walls and higher probability of flats. If doing heavy loader work or operation in wooded or rocky conditions R14s don't look like a option. More of a lawn and garden tire. A turf tire with a little better performance in snow.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
CASE TV620B SKID STEER (A52709)
CASE TV620B SKID...
2024 Bintelli ActivEV Pulse Electric Cart (A55853)
2024 Bintelli...
TANK MANIFOLD (A55745)
2021 Ford Mustang Mach-E AWD SUV (A55853)
2021 Ford Mustang...
