Anybody tried these traction cables instead of tire chains?
   / Anybody tried these traction cables instead of tire chains? #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
SCC Super Z8
They have a size that will fit my 15-19.5 rear tractor tires. They look easier to handle and to put on than regular chains. They're comparable in price to regular tire chains by the time you purchase the tighteners.
Our local fire department uses them on their apparatus and likes them.
   / Anybody tried these traction cables instead of tire chains? #2
on the highway dpt we used them on all our Dodge pick-ups and one ton dumps. Easy to install and they work well. Only time is if stuck in ice and starts spinning the tires, they come apart
   / Anybody tried these traction cables instead of tire chains? #3
I was just searching for something very similar to this and was wondering if anybody has any new information on these? I am looking to try and get some extra traction out of a Deere 3032e and am leaning towards these due to them being low profile.
   / Anybody tried these traction cables instead of tire chains? #4
Bad link. I had a set for my Ford Escort a long time ago. The cables didn't damage the tires as much as chains would. Worked very good in the wet packed snow you get in Western Washington and Oregon, and could run up to about 45 mph with them. Not so sure how they'd work for a tractor, but probably better than straight R4s when it comes to plowing snow.
   / Anybody tried these traction cables instead of tire chains? #5
Yeah that link doesnt work, I'll try and ad one. From what I could look up it looks like they should be about the right size. Can anybody confirm that they would fit the 15-19.5 r4's?
ZT892 - SUPER "Z" TRUCK CHAIN (Single)
   / Anybody tried these traction cables instead of tire chains? #6
Just bringing this back to the top to see if anybody can tell me if these would fit the 15-19.5 r4's. From my calculations they would.
   / Anybody tried these traction cables instead of tire chains? #7
Just an FYI, I went ahead and ordered these, couldn't pass them up at $100 from amazon. They fit just fine and are pretty heavy duty. Haven't used them yet but will post back when I do.
   / Anybody tried these traction cables instead of tire chains? #8
How did you calculate they were the right size for your tractor tires?
   / Anybody tried these traction cables instead of tire chains? #9
I figured out the rolling circumference from firestones website and did some more digging around to see that there were chains that would work for the same size tractor tire as mine and some of the sizes listed with the cables. In the end I was only about 80% sure they would fit, but they did. They go on super easy and came with tensioners.
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
(50) 2" X 2" X 41" TUBING (A54756)
(50) 2" X 2" X 41"...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2018 Ford Explorer SUV (A55758)
2018 Ford Explorer...
BUNDLE OF 82" X 49" DIAMOND PLATE SHEET METAL (A54756)
BUNDLE OF 82" X...
