timm9
I was supposed to pick up one of my Toolcats last Weds after the water in fusebox, possible animal "wiring" problem and the technician called saying that they noticed my "plate" was bent and also had cracks that needed to be welded.  The bend is symetrical and concave.  After much discussion about what the unit is/has been used for, which is only snow with a Bobcat blower and bucket, they are trying to get corporate to honor it as a warranty item.  The technician also asked if my newer unit (old one has 350+- hrs, newer unit has 230+- hrs) has a bent plate also.  I got off the phone, pulled off the blower, and discovered that the plate on the newer unit is bent also.  When holding a straight egde against the plate, the bend/bow is approximately 3/8".  Initially I had told the techician that I assumed they were designed that way and that the unit had just been in their shop for a service and had not been used since it's return.  The technician said they are not designed that wya, and after seeing mine he looked at their rental fleet (skids) which received alot of use/abuse and they are perfectly straight.  Please let me know if you have a bent plate as well, and if you do, what attachments you have been using.  The plate alone is $900.00+ not counting labor.
Tim
			Tim
