Anybody know of a 48" pallet fork with a bit of taper built into the SSQA plate?
   / Anybody know of a 48" pallet fork with a bit of taper built into the SSQA plate? #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
I'm looking for a set of pallet forks with a bit of taper built into the SSQA plate to aid in attaching to my tractor. Does anybody know of an OEM making pallet forks with a bit of taper?
Thanks ever so much.
For reference, this is what I'm asking about.
   / Anybody know of a 48" pallet fork with a bit of taper built into the SSQA plate? #2
The Versahandler bucket is straight with short angled guides to guide it on.
   / Anybody know of a 48" pallet fork with a bit of taper built into the SSQA plate? #3
My Artillian set is straight as a rail. No taper at all.
And yeah, it can be a challenge to see while lining up the connection.
My factory dirt bucket is the same. No taper.
   / Anybody know of a 48" pallet fork with a bit of taper built into the SSQA plate? #4
All my front attachments are straight. As I'm approaching the attachment with the tractor I lean over and sight along the tractor's SSQA plate to line it up. That makes it pretty easy.
   / Anybody know of a 48" pallet fork with a bit of taper built into the SSQA plate? #5
For pallet forks extra rollback built in is very important:
Here is a frame that dieselcrawler built with a lot of rollback:
   / Anybody know of a 48" pallet fork with a bit of taper built into the SSQA plate? #6
I welded a piece of 1/4x1-1/2x15 strip on the outside edge to help guide the loader into the pallet fork frame...worked so well I did the same to my grapple.
   / Anybody know of a 48" pallet fork with a bit of taper built into the SSQA plate? #7
Welded 1/2”x1.5”x15” flat bars on the sides of grapple ssqa to help connect. Quick and easy mounting now. Wish more were made that way. Pretty easy modification.
Kubota B26 HD bucket is the only manufacturer that I’ve seen with OEM side flares.
2019 Ford Explorer AWD SUV (A55853)
2019 Ford Explorer...
2016 Ford Explorer (A56859)
2016 Ford Explorer...
2 Cubic Yard Dumpster (A55851)
2 Cubic Yard...
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
2015 INTERNATIONAL FLATBED (A58214)
2015 INTERNATIONAL...
LMC G500-500A 72" Grapple (A56469)
LMC G500-500A 72"...
