Anybody here built a zip line?
/ Anybody here built a zip line? #21
The one's I have ridden (flown?) have had enough sag in them, with the starting end higher, so when you get to the designated spot you are going uphill again on the cable and naturally come to a stop. One particularly long one you would roll back and forth a few times before settling at the low spot. I don't think I'd want one where you could hit a tree!
Completely side note, I did another adventure race Saturday where there is normally a zip line. Instead, we rappelled off the face of a dam which ended in a 15 foot free fall to the water below. Was a blast!
/ Anybody here built a zip line? #22
I built one using stainless steel cable and some pullys from TSC. The riding element I welded together myself. One thing to work out is the tension of the cable - I ended up using one tightener in the line of cable an second one pulling it to the side forming a sort of Y on the bottom end of the line.
I test it myself every spring - 240 pounds make sure it is safe for the kids too:D
And tractor related part - there is an old garden tractor tire on the line to work as a stop/bumper.
/ Anybody here built a zip line? #23
Pulleys can be used to multiply the amount of weight used to tension the cable. A "block and tackle" is a good example.
Please see this for more info HowStuffWorks "How a Block and Tackle Works"
Using a block and tackle a 460 pound 55 gallon drum filled with water could be used to apply 920 or 1840 pounds of tension to the cable.
/ Anybody here built a zip line? #24
I think he's saying if you put a cable between two post and pull it tight, then measure the tension on the cable. If it gets cold, the cable contracts, putting more tension on, as it tries to pull the posts together. Conversely, if it gets hot, the cable expands and the tension on each end diminishes.
Can you see that in a long cable run, that could cause the cable to sag in the middle quite a bit in hot weather and pull very tight in cold weather.
Now put a 500 lb trolley on that cable. In the winter, the trolley may get you over most objects very fine. In the summer, it may dip too low to get you over those objects. Lets hope the zip line doesn't run over a cactus patch! :)
By putting some weight on the cable past one end point, you can keep the cable at the same elevation all year.
At same elevation and under same tension!
Pullies will actually multiply forces as in a come along or as on a winch using a pully.
One pulley does nothing but 2 doubles 3 tripples the forces or tension.
No pulley, ie fixed attachement at both ends could actually pull the anchorage out of the ground given the proper temp swings or at worse place so much tension on the cable as to even snap it, never mind the fact that at the center of the cable on a hot day you might just clear the ground and in the coldest you would be as high as your ancorage points.
A good sound tree as one anchorage would take care of tension problems as a tree is flexible and would act as a big spring or bungee.
/ Anybody here built a zip line? #25
A pulley all by itself dosen't multiply force. The pulling force is multiplied by splitting the counter force. Example: If I am winching a truck up a hill I can use a pulley (snatch block) to double the pulling force of the winch by running my winch cable through the snatch block and back to the winch (or a tree beside me would be safer) The snach block is then anchored with a chain to the truck. The hook at the end of the winch cable is now taking half the load and the winch itself is taking the other half.
If I were to just hook the end of the winch cable to the truck with the snatch block chained to a tree I wouldn't gain any pulling force.
/ Anybody here built a zip line? #26
the tension in the string (cable) is always the same. i dont care HOW many pullies you put on the end. its still only (say) 500 lbs hanging off the end of the cable.
When done properly the end of the zip line cable is not the same as the cable holding the 500lb weight. The line with the weight, goes from the weight, to a pulley on a block, and back to an anchor, back to the pulley, back to the anchor, back to the pulley, etc. The zip line is connected to the block .
/ Anybody here built a zip line? #27
The zip line I rode in Ketchikan used two cables for each run.
/ Anybody here built a zip line? #28
Above info well presented,
but may I add:
Seasonal temperature changes will add stress (tension) as metal shrinks with cold!
For that reason ski tows always used weights at one end to keep tension constant.
I believe the safe way would be dead weight via pullies hung at one end.
With pullies you can 1/2 or 1/4 the needed weight.
Even bridges have expansion joints!
(not calculated) but even a 45 gal drum filled with concrete might be all you need (with pullies as multipliers)
I really don't see thermal expansion being a big factor. In 00 feet, I think it will be only a small amount, given a 80 degree temperature swing. Bridges have expansion joints, but the structure is a lot more complex than a "string" of steel. As I recall, the coefficient of expansion of steel is 60 millionths/inch/degree. I see steel wires all over the place, and they aren't sagging a whole bunch.
/ Anybody here built a zip line? #29
Sorry, should have been "In 100 feet"!! duh!!!
/ Anybody here built a zip line? #30
The zip line I used has a tire stop towards the end so that you didnt go crashing into anything. The sag was also like a break slowly stopping us.
This was off of a 50' high telephone platform, you were harnessed in and you stepped off the platform and away you went.
I would look at Project adventure- Project Adventure - PA.org --they do the outdoor courses, training, and constuction
High and low course rope designs (google it)
A lot of boy scout camps have COPE courses now....challenging outdoor personal experience (cope). They will have climbing towers and high and low course events.
/ Anybody here built a zip line? #31
I built two zip lines on our property. The large one is 330 feet in length and is over 30 feet high when you cross the creek. I used 7/16 aircraft cable that I purchased from a cable specific supply house. I used treated 2x4's vetically on the back side of the tree trunks to protect the bark. One very important factor is to use very good cable clamps. I used Crosby clamps that are forged and have specific torque requirements. Remember, "never saddle a dead horse" when clamping.
Home
I purchased a Petzl tandem speed pulley that is rated for this exact purpose. http://www.petzl.com/us/outdoor/transport-pulleys-0/tandem-speed
We also purchase a couple of Petzl harnesses and webbing. Learn the correct knots for the webbing.
http://www.petzl.com/us/outdoor/harnesses-0
Here is a youtube link to me riding the zipline. You can hear my mother-in-law asking my wife "how did he put up the cable?" My wifes answer makes this post all the more fitting.
http://www.youtube.com/watch?v=Lh39z3o0BQ8
/ Anybody here built a zip line? #32
Any updates to the the Zip Line projects in the last 12 months?
Works great. Just a bit cold to drop off onto the frozen lake right now. :)
/ Anybody here built a zip line? #34
Any pics/details? I've toyed with the idea for a future project. Got several spots on 2 properties that could be well utilized. Problem is, terrain is differing heights.....so how to return the carriage......?
I built a launch platform about 10' tall on top of the dam of the lake, which is about 8' high, and the run is around 350' long. To return you just unclip the trolley from the cable and carry the rigging back to the launch platform. Generally they have my RTV1100 and an ATV running back and forth to avoid the "long" walk. No elevator on the launch platform though. They have to climb the stairs up to the deck. :D
Seriously speaking, the kids and dozens and dozens of guests had a blast on it last year. I have 2 different sets of handles and a seat. The seat is generally used if you are going to just ride the zipline all the way across the lake and not drop in. You just drag your feet on the far end or, with kids, have someone 'catch' you. The end of the line is a section of railroad track sticking up out of the ground with a cable holding it back to an anchor point. Even with only about 5' of a 12' section of track sticking out of the ground, the track bent when I was first applying tension to the cable. The cable does pass through 2 old tires before the track, so you'd be stopped and fall onto the ground rather than clanging off the track. ;)
/ Anybody here built a zip line? #36
I've got a property in Iowa with a large creek, 60 feet wide and 15 feet deep that can't be crossed for much of the year. In the Spring, it often jumps its banks and carries large trees along with it. A bridge is not practical. There are some very nice woods on the other side we like to walk in.
I'm putting up two zip lines, one going and one returning, so my wife and I can get across this creek all year. I'm still in the middle of the project but I will post more about as we do our first experiments.
I'm using deer hunting ladderstands as my starting platforms. I chose the Big Game Partner Plus because the platform could hold two people and was the largest available.
Here's a great source for zip line gear and technical help:
Home | Zip Line Gear .com
/ Anybody here built a zip line? #37
The stress on the cable can be a large multiple, sometimes 11 times or greater, of the weight on the line. I am hoping that you are securing the cable to something substantial. In the previous post Dargo mentioned bending a 5' section of railroad rail that he had attached the cable to.
I am planning to build a gondola type system to travel about 200' up and down a 30 degree slope. If I do so the towers on each end will be made from 10" to 12" I-Beams or Tubing with triangular braces and several yards of concrete.
/ Anybody here built a zip line? #38
My cables are anchored to large locust trees, not to the platforms. My lines are only 100 ft in length. According to the Ziplinegear.com web site, 1/4" cable kits will support a 350lb safe working load. I'm using 3/8" galvanized aircraft cable with a 14,000 lb minimum breaking strength. I'm way over engineering this project.
Your gondola project is much more challenging to engineer. A heavy gondola 200 ft along a 30 degree incline! A lot of potential energy stored there! I hope you have some kind of redundant braking just in case something gives way.
/ Anybody here built a zip line? #39
Yes there will be multiple brake systems. Starting with 2 to 4 drive hoists including their own braking, a rubber based brake system to slow the carts with friction on the cables and likely metallic cable brakes. I have also considered a manual release which would drop the gondola from the overhead cables. It would be no more than a few feet from the ground and the bottom would be sufficiently bumpy to stop it from sliding down the slope.
/ Anybody here built a zip line? #40
I think a manual brake might be a better idea than having a release that could drop the gondola and let it bounce down the slope (in a worst case scenario).
Aaron Z
UNUSED KJ K4230W-42'X30' METAL STORAGE SHED (A60432)
UNUSED KJ...
SAMSUNG REFRIGERATOR/FREEZER (A60432)
SAMSUNG...
10ft. Fork Extensions (A59228)
10ft. Fork...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
