Anybody got one of these yet? Raven mower.
   / Anybody got one of these yet? Raven mower. #51
Hey Guy's, just wanted to let you know I actually took the plunge and bought one of the Ravens from Lowes about a month ago. I love it. Yes, it has a few bugs that need to be worked out, like any new product, but it seems pretty solid. I bought it to use at my remote cabin property in the mountains. Problems I've had so far. The 12 volt battery has something draining it's power in during down time. Raven is sending me a diode so I can fix it. The seat switch lever is too flimsy. Again they are sending me a new and improved version to replace the weak one. The positives. This thing is awesome. It has a two speed rear end, so I can drop the mowing deck and use it as a ATV. The factory tires are typical lawn and garden types, so I ordered some decent ATV tires a few sizes bigger and installed on the rear, plus I fabricated a mount on the front and installed a winch. Yeah it has a few bugs, but I am reasonably handy with a wrench and meter, heck I built a towable back hoe last year and it works great, so I figured the Raven would not be a huge undertaking. Hope this helps answer some questions you may have.View attachment 309992
It looks like you have the rear tires reversed from normal forward pulling. Did you put them of that way for a reason?
   / Anybody got one of these yet? Raven mower. #52
Aczlan,
To run in all electric mode you just get on the machine and turn the key to the battery symbol, release the break and select forward or reverse and press the pedal. The specs suggest it will last approximately 1 hour on the battery without running the engine. And yes, there are only 120 volt outlets on the generator, with the exception of a 12 volt dc outlet (cigerete outlet), and a 48 volt recepticle for plugging in a optional 48 volt d/c charger.
Thanks for the info.
Aaron Z
   / Anybody got one of these yet? Raven mower. #53
Honestly I did'nt pay attention to how they were mounted. I will say this about the tires. I have a steep bank in front of my home and the raven trammed right up the bank with no problem at all. Kinda of fun, but the wife chastised me for it, saying I will wreck. Gotta be carefull to make sure she does'nt see me do that anymore.
   / Anybody got one of these yet? Raven mower. #54
The recall took too long I bailed. I will wait until next year when the add 240v to the generator.
Darn right. Is it confirmed that they are going to a 240 gen? That is so essential to supplying emergency power that I would not consider buying without it.
larry
   / Anybody got one of these yet? Raven mower. #55
I looked at it at Lowe's also. Neet idea but the mower deck apeared cheaply made and small. I will keep an eye on the reviews over the next year and if they are good, i may end up with one.
   / Anybody got one of these yet? Raven mower. #56
Actually I measured the metal on the deck and it is about 1/8 on an inch thick welded steel Not spot welded, actual welds. It's pretty strong, much stronger than my craftsman deck I've used for the last 6 years. Heres a pic of a section of the deck that shows the welds. raven mowing deck welded.JPG
   / Anybody got one of these yet? Raven mower. #57
peavey, I looked at the pdf for this mower, and could not find the specs for maximum cutting height. I need to cut as high as possible. Thanks for the info. The deck appears fairly substantial in the picture.
   / Anybody got one of these yet? Raven mower. #58
The mowing deck in the highest position is about 4 1/2 inches from the ground. I'm not sure of the recessed height of the blades with in the deck.mowing deck clearence.JPG
   / Anybody got one of these yet? Raven mower. #59
   / Anybody got one of these yet? Raven mower. #60
I saw one at Lowes this weekend, my first thought was that it looked like Batman's lawnmower. :laughing:
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2025 New/Unused Wolverine Snow Pusher (A51573)
2025 New/Unused...
2024 JOHN DEERE 4044M LOT IDENTIFIER 62 (A53084)
2024 JOHN DEERE...
2020 JOHN DEERE 8R 250 LOT IDENTIFIER 172 (A53084)
2020 JOHN DEERE 8R...
2019 John Deere S780 Combine (A53342)
2019 John Deere...
