Anybody got a new 425 with a Kohler engine?
   / Anybody got a new 425 with a Kohler engine? #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I am curious how it starts in cold weather, how the power feels, and if it is fuel injected. Any other comments would also be appreciated.
   / Anybody got a new 425 with a Kohler engine? #2
I talked to Terry the other day and we talked some about the new power trac with the Kohler engine and he said they start much better than the Subaru in cold weather.
   / Anybody got a new 425 with a Kohler engine? #3
I put a fuel-injected Kohler in my 425 after frying the original Subaru engine. The Kohler is way easier to start in cold weather.
Thanks to both of you. Good to hear.
   / Anybody got a new 425 with a Kohler engine? #5
Welcome to the Power Trac forum on TBN! :thumbsup:
   / Anybody got a new 425 with a Kohler engine? #6
Which engine model?
   / Anybody got a new 425 with a Kohler engine? #7
I got the ECH740-3007.
Used to be rated at 27 hp, but same engine is now rated at 25 hp.
   / Anybody got a new 425 with a Kohler engine? #8
How much did you have to revamp, or what off the Subaru fit on it, such as the exhaust header or other things. That is my only real complaint about the Subaru, after doing all the modes, is it is still a bit hard to start in the cold, but with the hydraulic tank pad on it, and a full charged battery it will start.
   / Anybody got a new 425 with a Kohler engine? #9
I would like to know if anyone put one of those little 2 cylinder diesel engines in one and how does it work for them. I wouldn't mind having a diesel in mine.
   / Anybody got a new 425 with a Kohler engine? #10
It was reasonably simple.
I had to drill a couple of new holes in the tub to accommodate the slightly different motor mount geometry and I had to adapt some of the wiring. But attaching the throttle cable was easy and the choke cable is now irrelevant.
I also had to move the battery to make room for the exhaust header/muffler unit. I didn't want to mess with its placement because the fuel injected engine relies on a sensor seated in the muffler.
I ended up going with a lithium ion motorcycle battery that sits inside the tub. seems to work fine.
I'll try to post a picture if that's not clear.
Trailer (A56858)
Trailer (A56858)
CANOE (A56859)
CANOE (A56859)
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2007 PETERBILT 385 CAB AND CHASSIS (A58214)
2007 PETERBILT 385...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
