Anybody got a new 425 with a Kohler engine?
   / Anybody got a new 425 with a Kohler engine? #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I am curious how it starts in cold weather, how the power feels, and if it is fuel injected. Any other comments would also be appreciated.
   / Anybody got a new 425 with a Kohler engine? #2
I talked to Terry the other day and we talked some about the new power trac with the Kohler engine and he said they start much better than the Subaru in cold weather.
   / Anybody got a new 425 with a Kohler engine? #3
I put a fuel-injected Kohler in my 425 after frying the original Subaru engine. The Kohler is way easier to start in cold weather.
Thanks to both of you. Good to hear.
   / Anybody got a new 425 with a Kohler engine? #5
Welcome to the Power Trac forum on TBN! :thumbsup:
   / Anybody got a new 425 with a Kohler engine? #6
Which engine model?
   / Anybody got a new 425 with a Kohler engine? #7
I got the ECH740-3007.
Used to be rated at 27 hp, but same engine is now rated at 25 hp.
   / Anybody got a new 425 with a Kohler engine? #8
How much did you have to revamp, or what off the Subaru fit on it, such as the exhaust header or other things. That is my only real complaint about the Subaru, after doing all the modes, is it is still a bit hard to start in the cold, but with the hydraulic tank pad on it, and a full charged battery it will start.
   / Anybody got a new 425 with a Kohler engine? #9
I would like to know if anyone put one of those little 2 cylinder diesel engines in one and how does it work for them. I wouldn't mind having a diesel in mine.
   / Anybody got a new 425 with a Kohler engine? #10
It was reasonably simple.
I had to drill a couple of new holes in the tub to accommodate the slightly different motor mount geometry and I had to adapt some of the wiring. But attaching the throttle cable was easy and the choke cable is now irrelevant.
I also had to move the battery to make room for the exhaust header/muffler unit. I didn't want to mess with its placement because the fuel injected engine relies on a sensor seated in the muffler.
I ended up going with a lithium ion motorcycle battery that sits inside the tub. seems to work fine.
I'll try to post a picture if that's not clear.
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
