Any woodturners out there?
   / Any woodturners out there? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
I am readying to buy a wood lathe. Looking at a mid size 16x24 Possibly a Nova Saturn DVR. Not sure I need/want a full size lathe for say, table legs as I plan to do more bowl turning type of work. Question... do you think I will kick myself for not splurging for a full size? I guess the question is how many of you turn long pieces vs. short for the various projects you do?
   / Any woodturners out there? #2
I do a bit and have a Record short bed with outboard turning, I find it a bit tedious after a while and cannot get into pen turning but sometimes wouldn't mind something bigger.
I tend to turn replacement parts for furniture such as finials for clocks which I collect.
Don't know how much you have turned but I use gouges for most work and have a white wheel on a grinder next to the lather for sharpening which takes a few seconds once you can sort your angles and get it right each time, a 4 jaw chuck.
The downside of Record is that it uses #1 morse taper, almost everyone else uses #2 which is cheaper and more common.
Good steel for makes life easier too as it holds its edge, cheap sets are generally next to useless.
Nova is a good brand but there are a lot of others too and look at 2nd hand as a lot of people invest and lose interest quickly.
I’m pretty efficient at knife sharpening and have a nice Tormek for that. I have never owned a lathe but took a class recently and the bug bit me. Am looking 2nd hand but really like the direct variable drive feature of the newer machines.
   / Any woodturners out there? #4
I've got a cheap long lathe and am on the lookout for an inexpensive or used lathe that would give me 18-20 between centers. I thought I'd be doing things like table legs, but that hasn't been the case. I think if I'd started with a shorter lathe, I'd simply turn what I could and dowel and glue up into something longer.
The upside is I've got a fair idea of what I'd like. If you go for a long work, be aware that thin and long require stabilizers, and there is a point that you can't exceed.
   / Any woodturners out there? #5
I’ve got a Jet 16-42 and a Powermatic 35-20. I don’t use the length very much ( other than sliding the tailstock out of the way) but I think you’d miss the weight and power of a full-size lathe.
   / Any woodturners out there? #6
Although I know one person who makes flagpoles up to 80' long, but there are a lot of stabilisers and it is slow turning compared to short beds.
Also, a short log can be character building when it jumps off the lathe, I have had that happen a couple of times.
Weight is definitely nice. Being able slide the tail stock out of the way seems a plus.
I used two lathes in a class. One a full size I definitely liked better because of the weight and power and low vibration.
I don’t see me doing table legs but maybe pool cue sticks, I don’t know.
   / Any woodturners out there? #8
Full size for the weight if you wish to turn anything of any size & having the tail stock out of the way is a plus.The variable speed is nice as well.
   / Any woodturners out there? #9
My wood lathe is a full size Rockwell, I like having the option to turn what I want, a bowl or a leg.
SR
   / Any woodturners out there? #10
Another plus is lever adjustments on everything, tightening and loosening nuts becomes very tedious and time consuming especially when you need to make minor adjustments.
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
Ford Tractor (A50120)
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
