First run of the 322d went well. No major issues, but a few small fixes needed.
Ran her up to speed and rpm’s were a bit below spec of 3200, but close enough for me. This tractor will be running a rotary broom, so I’m not too worried about pto rpm.
The charging system is working as advertised.
All other systems appeared to be operating fine. She ran, drove, and stopped well with no strange noises.
There were a few small issues:
- The engine does not shut off with the key. To kill it I had to push in on the rubber cap on the back of the injector solenoid. Strange thing is it worked when I first got the tractor. I’m wondering if changing the key switch may be the problem.
- I have a small oil leak on the front of the oil pan. Might be front main seal, or oil pan gasket. Either way, it’s not bad enough for me to worry about. It does not leak with the engine off, only while running. May try some stop leak in there if it keeps up.
Next I need to install the broom, doesn’t look fun.
