Any tips for 1 man implement hook-up?
   / Any tips for 1 man implement hook-up? #91
In ten minutes with IMatch I can pick up (move over to mow beneath) 4 ot 5 implements without getting off the tractor.
Are they all JD implements? Does the Imatch spacing work with other brand implements? I have Woods and Bush Hog attachments.
Ken
   / Any tips for 1 man implement hook-up? #92
does it hookup the pto shaft for ya? :)
deriously though, whatever works, and every lil bit helps.
( speaking of auto pto shaft hookup... havn't I read that deer has something like that in limited release? )
soundguy
I haven't added the auto shaft portion to my IMatch but it is available for my implements. I did try it at the dealer and it works pretty slick, for someone starting out with a clean slate (no existing equipment) I think it is a good way to go.
When I am moving my implements to mow beneath them I don't need to hookup the pto anyway. I have fixed link, telescopic link and IMatch and the latter is much easier to use by myself.
   / Any tips for 1 man implement hook-up? #93
Ken
Ken,
The IMatch will work with most Cat 1 implements though some need modifying. There are a few that would require major changes to work. Once you have them setup though the IMatch is a joy to use.
Having the IMatch and knowing what it needs to work I am aware and pay attention to this when buying future implements. I have a variety of brands of implements and most have needed only simple modifications to make them work.
   / Any tips for 1 man implement hook-up? #94
My only tip is to make sure the wife or kids arent around. Dont want them to hear you cussing. :thumbsup:
   / Any tips for 1 man implement hook-up? #95
Good boots(as hammers):thumbsup:
   / Any tips for 1 man implement hook-up? #97
42 oz. deadblow mallet.
That and a good pry bar can make things a lot easier. Park your stuff on pallets with wheels on them if they are on concrete.
   / Any tips for 1 man implement hook-up? #98
+1 on the mallet and prybar -- I have a six foot "railroad pry bar" that I always use when attaching implements -- I have a quick hitch but find it kinda a waste of time :eek:
   / Any tips for 1 man implement hook-up? #99
How do you find it a waste of time?
I find the brute force method to be a waste of time, growing up we didn't have I Match and had to use the brute force method. If you take the time once to make the quick hitch work it saves a great deal of time. I find that the quick hitch combined with top n tilt makes a good combination.
When I build implements I make sure they are compatible too. Usually a few simple modifications and most implements can be quick hitch ready. Guess it helps to have some welding equipment but with what I know now I would pay a welder to do the work if necessary.
   / Any tips for 1 man implement hook-up? #100
After getting the iMatch, I don't need any of the bars or heavy boots or heavy mauls to hook-up. It is a real pleasure compared to the sweating that I used to do. Now I will admit to a tilt a time or two, just because the implement shifted or I approached at a different angle, and admit that the hyd. top arm is a real blessing as well. But no sweat now. :thumbsup: :cool2:
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
NEW Landhonor 5400LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2024 ArmorLite Aluminum End Dump Trailer (A56435)
2024 ArmorLite...
