Any thoughts on the Walmart Super-Tech Moly grease?
   / Any thoughts on the Walmart Super-Tech Moly grease? #1
Snatchface
VT
Kubota BX24
I am thinking about dropping the $265 on a case of TRC 880 moly but this is definitely overkill for me with my single tractor...unless some people here want to split the case with me. I assume that one 14 oz canister would last me about a year. Otherwise the Super-Tech stuff is cheap and convenient. ANyone have any experience with it? My mechanic swears by it, but I know that doesn't really mean all that much.
   / Any thoughts on the Walmart Super-Tech Moly grease? #2
Since I don't know what tractor you have (hint update your profile hint) it's hard to say. FEL pins are usually the item that needs greasing most often. I am using a 14oz tube of grease approximately every 40 hours of runtime. Unless you are running 100's of hours a year, an enormous tractor that takes ounces in each fitting, or a backhoe with 30+ fittings, I think this purchase would be misplaced.
Thanks. Profile updated. Yah I definitely don't need a case but I am quite **** and tend to be a perfectionist about machine maintenance. I want the best stuff, just not two lifetimes' worth of it. But I would want to know that what I was using was a reasonable substitute.
   / Any thoughts on the Walmart Super-Tech Moly grease? #4
Ok, so you have a FEL and backhoe. A fair number of grease fittings. IMHO, I would buy some premium name brand, one case, and you should be good for a couple years. I personally am using JD grease; there are several threads with recommendations, many from DieselPower who's in the business.
   / Any thoughts on the Walmart Super-Tech Moly grease? #5
There are already a couple of good grease threads in the Oil, Fuel and Lubricants section. One of the more recent is titled Bulk Grease Choice.
Since you have a FEL and a BH I would highly recomend a Moly fortified grease. You also might consider buying your grease in a pail instead of in tubes. It's cheaper in pail quantity and you never have to change a grease cartridge again when you use a bulk loader pump.
I have read through every related thread in the last 15 pages of threads...I told you I was ****. I am interested in cartriges just because I can't see myself ever needing bulk grease. I was hoping I could find some people here to split a case of TRC cartridges with me.
Anyway, one thing I didn't get out of all that reading - would the savings for a pail offset the cost of the pump? No point in saving a few bucks on a single bucket which will last me a lifetime if that saving is offset by the cost of a pump. Know what I mean?
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2007 FORD F250 XL SUPER DUTY TRUCK (A54756)
2007 FORD F250 XL...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
