Any structural use of Maple?
   / Any structural use of Maple? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So we have a ton of maple trees on our property (well, not a ton but enough). A few of them have to go. They are nice 50ft and straight, maybe 24 to 30 inches at the base.
I know I can use it in furniture (have no clue how to make furniture but that is a different conversation). Is maple any good for structural construction? I think not as I have never seen it used except for fashion items.
Hate to burn it up but....
   / Any structural use of Maple? #3
A furniture maker around your area might be interested in buying your logs or even working out a trade. Might be worth a little time to ask around.
Downsize, thanks for the link. Had not heard of them.
But let me rephrase. Is Maple a suitable lumber for building an outbuilding? If I where to slab it up, would I be able to use it? I think it is a very wet wood so might just take too long to dry....
   / Any structural use of Maple? #6
woodlandfarms,
What species of maple? That will make a big difference.
   / Any structural use of Maple? #7
Mechanical Properties of North American Hardwoods
I used some years ago for the base of a tool shed,, used an Alaskan saw mill to cut it up.. It's still standing,, :)
   / Any structural use of Maple? #8
woodlandfarms,
I'm not the op, but I'd guess that they're bigleaf maples. That's what grows in Washington anyway.
As for your question, yes, you ought to be able to build an outbuilding with it. You can check the strength rating of wood by species online. There aren't too many types of wood you can't build a shed with.:)
   / Any structural use of Maple? #9
It is not used for structural wood because it has more value as a hardwood. It is a stronger wood than pine, spruce, and hemlock. But being a hardwood, it is more difficult to work with, and drying is more of an issue.
MapleInfo.org - Maple Lumber Properties & Uses
Yup. Big Leaf (The leaves on these trees are like 12" across - crazy huge).
And thanks for all the notes. I am going to stare at it long enough to see if I can make furniture. I own, and am a huge fan of atomic modern, especially heywood wakefield furniture (our house in LA is a 50's modern)
Just not sure I have the patience or skill for woodworking.
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
1982 LeeBoy Motor Grader (A55218)
1982 LeeBoy Motor...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
