Forks Any source of "hanging" pallet forks for a B7610?
   / Any source of "hanging" pallet forks for a B7610? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
The B7610 FEL has a lift capacity of about 700 lbs. I'm wanting to get a Piranha for it AND pallet forks. Bxpanded doesn't sell forks to fit for the B7610. I kind of like the concept of the "hanging" pallet forks.
Is there another mfg that makes that that type of fork?
   / Any source of "hanging" pallet forks for a B7610? #2
Newbury, are you referring to the type of pallet fork that is hinged to the top part of a FEL bracket that sits in place of a bucket? If so, I may be able to help you
Smalltrac
subcompacttractorworld.com
Yes sir
/edit -
Smalltrac - I may have misinterpreted your post. I'm looking for something like the SS fork hinged to the top of the FEL (like Bxpanded produces).
   / Any source of "hanging" pallet forks for a B7610? #4
If you are interested, perhaps you should Private message me and we can talk sizes and prices. Or if you prefer, we could exchange emails.
Smalltrac
Subcompacttractorworld.com
   / Any source of "hanging" pallet forks for a B7610? #5
Is this the type that you are looking for?
Found them on eBay, 48" pin mount block forks. I already had the frame, it was made by a local company.
Used Pin Style Block Forks 48" Long | eBay
   / Any source of "hanging" pallet forks for a B7610? #6
Your gonna loose a lot of lifting capacity with that type of forks
   / Any source of "hanging" pallet forks for a B7610? #7
I had an old set of Wifo forks of that type. I'm sure that the OP has his reason for wanting that style, but they weren't cutting it for my use. If I wanted to tip a pallet or otherwise tip the load to have it slide off onto the ground or into the truck, it wasn't happening. Same thing if you need to approach something at an angle, with the fork tips lower than the carriage. If you needed to pick a large rock out of the ground, for instance.
No, I don't think the lifting capacity will come unfastened.
And if you meant LOSE capacity, part of the reason I wanted the Bxpanded style was that they were only 45 lbs/pair. I presently have a pair of 48" Titan's clamped on and they work, but weigh about 100 lbs.
I've read several threads from users of the Bxpanded forks and found no mention of that problem.
http://www.tractorbynet.com/forums/kubota-owning-operating/142663-bxpanded-bucket-forks-2.html is perhaps the longest.
   / Any source of "hanging" pallet forks for a B7610? #9
As I said, you know best what you need them for. They weren't worth a toot for my use.
That thread didn't really seem to provide a whole lot of worthwhile information other than everyone liked BXpanded and Harry. Nothing wrong with that information either.
   / Any source of "hanging" pallet forks for a B7610? #10
Take a look at this picture, notice the chains that allow flexibility on uneven ground and dump angle.
It looks like the Bxpanded forks are rigid on the bucket.
2022 Bobcat ZT3000 52in Zero Turn Commercial Mower (A49461)
2022 Bobcat ZT3000...
2006-2009 Ford 4x4 Pickup Truck Bed (A49461)
2006-2009 Ford 4x4...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
