Any source for John Deere MX6 cutter parts?
   / Any source for John Deere MX6 cutter parts? #81
I don't recall hearing of this issue with any others. I run a 2004 MX6 with a Spain gear box. Before reading these stories of failed gear boxes I would back down pond dam and push over and lower down on probably 4" trees and mulch them into chips. Was doing this before realizing the need to slip the clutch annually. Have run over an old gear box once that hit hard enough to make a visible dent in the side wall even though it is double walled. So far no issues whatsoever.
Have considered selling it and buying a Bush Hog brand 286 or equivalent but have run a 285 5' cutter and actually like the cut of the MX6 better. At this point planning to stick with it since is 10 years old and no issues and very satisfactory performance.
   / Any source for John Deere MX6 cutter parts? #82
I have a MX5 and the shaft broke on mine too. I was mowing grass when it fell out the bottom. I bitched at JD to try to get some help with fixing it. And JD didn't want to do anything for me so I put it out back on the junk pile. 2 yrs. later I was checking out the Gator 825i and was making a deal with my local dealer and I brought up the issue about the MX5 and the Dealer said he would look back into helping me fix it. Well long story sort, They got me a new gear box at No Charge but I had to buy the new pan at $750 to fit the new China gear box. So now I have a working MX5 and a Gator 825i loaded and a happy owner !!
   / Any source for John Deere MX6 cutter parts? #83
Only reason I got rid of my mx6 is I somehow bent the pto shaft. Never figured out how either and I've never bent another one on any other cutter I've had and they were used way harder then it was. I priced a new pto shaft and of course it was almost $1000. I said heck with this and sold it and bought me a Bush Hog BH16. Doesn't cut as nice as the mx6 but it sure is tougher then the mx6.
   / Any source for John Deere MX6 cutter parts? #84
Yeah the MX series do cut nice as they have a very high blade tip speed.
   / Any source for John Deere MX6 cutter parts? #85
I have a freshly redone MX6. It looks like new. It has the gearbox from a 709 on it. Works great. Too dang heavy for my farmtrac 545. I have to weight the front end a whole bunch. Ill sell it off if anybody wants it. I am in Gulfport MS
   / Any source for John Deere MX6 cutter parts? #86
We are now stocking replacement gearsets for the JD MX5, MX6 and MX10 with Iberia Spain made gearboxes. Ken Sweet
   / Any source for John Deere MX6 cutter parts? #87
So this will fix the Spain gear boxes that broke the shaft? Also can reuse the old pan?
   / Any source for John Deere MX6 cutter parts? #88
Yes it will, however, we are currently our of stock until the first week in July. We do have in stock the kit for the MX10 cutters. Ken Sweet
   / Any source for John Deere MX6 cutter parts? #89
Awesome, I just picked up an older mx6 for stupid cheap. Works flawlessly but incase somthing happened I know I can get parts
   / Any source for John Deere MX6 cutter parts? #90
I have both an mx6 & 286, that 286 cuts way better than what that mx6 does. It's honestly no comparison, that mx6 looks like you whipped the grass with a logging chain. I've had 3 different John deere cutters and all 3 of them cut like that. That bush hog cuts way better than what that John deere does !!
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A58376)
UNUSED FUTURE...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2010 SHOP MADE LIMA MAC 60KW GENERATOR (A58216)
2010 SHOP MADE...
2012 SHOP MADE DUETZ MARATHON 60KW GENERATOR TRAILER (A58216)
2012 SHOP MADE...
2024 JOHN DEERE 50 P-TIER EXCAVATOR (A52709)
2024 JOHN DEERE 50...
