Any rule-of-thumb for replacing 4.5" cutoff wheels?
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've read of them shattering and I'm apprehensive of getting shards in my body even though I wear PPE.
But presently the roofing metal I'm cutting is eating about 1 Dewalt DW8062 wheel per panel width.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #2
I cut roofing metal with my skilsaw, way faster, easier and I think safer. I dedicate my old blades to that task. But when I use a grinder I go until I can't cut all the way through a channel of the roofing then swap out so probably ~40% smaller when I'm done?
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #3
Something's wrong...you should be able to cut most roofing metal all day long with the same wheel...!
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #4
Don't buy harbor freight cutting wheels...stick with diablo or dewalt.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #6
If you are using it to cut look for one of those Diablo or Lenox diamond metal cutting blades. On 1/4" steel they don't cut as fast as an abrasive cutting wheel but they last 1000times longer.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #8
That sounds about right in my experience. Cutoff discs don't last long but are cheap. I recently cut about 20-30 8" I beams with a stack of these. Just need to go slow and no twisting. There are maybe better options as noted by others but I have about 50 more to go through and they work. Just keep a wrench handy.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #9
For roofing, use a circular saw with a metal cutting blade. The grinder will heat the metal too much and be more likely to cause rust issues in the future. I made all the cuts necessary for my pole barn with one metal cutting blade and it's still in good shape.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #10
Never use them without wearing protective gear and clothing.
When I use abrasive cut off wheels I have a face shield, leather arm covers, leather apron, and leather gloves on.
I use the 4-1/2" discs until they wear down to the grinder head.
I have had a few come apart. If I see a nic in the edge I throw it away. I had a 7" disc explode on my chop saw and shatter the guard. One piece actually hit my face shield. 99% of the time they wear evenly until they are worn out.
2012 International Prostar (A56435)
2012 International...
10' CONTAINER (A52706)
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
Utility Cart (A56857)
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
