Any rule-of-thumb for replacing 4.5" cutoff wheels?
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've read of them shattering and I'm apprehensive of getting shards in my body even though I wear PPE.
But presently the roofing metal I'm cutting is eating about 1 Dewalt DW8062 wheel per panel width.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #2
I cut roofing metal with my skilsaw, way faster, easier and I think safer. I dedicate my old blades to that task. But when I use a grinder I go until I can't cut all the way through a channel of the roofing then swap out so probably ~40% smaller when I'm done?
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #3
Something's wrong...you should be able to cut most roofing metal all day long with the same wheel...!
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #4
Don't buy harbor freight cutting wheels...stick with diablo or dewalt.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #6
If you are using it to cut look for one of those Diablo or Lenox diamond metal cutting blades. On 1/4" steel they don't cut as fast as an abrasive cutting wheel but they last 1000times longer.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #8
That sounds about right in my experience. Cutoff discs don't last long but are cheap. I recently cut about 20-30 8" I beams with a stack of these. Just need to go slow and no twisting. There are maybe better options as noted by others but I have about 50 more to go through and they work. Just keep a wrench handy.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #9
For roofing, use a circular saw with a metal cutting blade. The grinder will heat the metal too much and be more likely to cause rust issues in the future. I made all the cuts necessary for my pole barn with one metal cutting blade and it's still in good shape.
   / Any rule-of-thumb for replacing 4.5" cutoff wheels? #10
Never use them without wearing protective gear and clothing.
When I use abrasive cut off wheels I have a face shield, leather arm covers, leather apron, and leather gloves on.
I use the 4-1/2" discs until they wear down to the grinder head.
I have had a few come apart. If I see a nic in the edge I throw it away. I had a 7" disc explode on my chop saw and shatter the guard. One piece actually hit my face shield. 99% of the time they wear evenly until they are worn out.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
2015 Jeep Patriot Sport SUV (A48082)
2015 Jeep Patriot...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
2005 International 8600 Hydro Vac Truck (A50860)
2005 International...
UNUSED Brown Metal Roof Wall Panels (A50860)
UNUSED Brown Metal...
