Any recommendations for a chipper for B2601?
   / Any recommendations for a chipper for B2601? #1
Haff
Kubota B2601
I plan to take down somewhere between 100 and 200 trees and dont really feel like having constant burn piles, so I'm thinking about getting a chipper. Do you have any recommendations for one?
Thanks.
   / Any recommendations for a chipper for B2601? #2
Thanks.
Take a look at Woodmaxx chippers. With only 20 hp at the pto, you will be limited to chipping around 4 inch hard material and around 5 inch soft material.
With that many trees, renting a larger commercial model would make more sense to me.
   / Any recommendations for a chipper for B2601? #3
I agree with Chewwy re renting a commercial chipper. I've had a TPH-122 MacKissic for 16 years, but it only does up to around 3 to 3 1/2 inch and hand feed.
Ralph
I'm going to be dropping the trees slowly over a period of months though, so I would have to have huge piles waiting. Might be an option though.
   / Any recommendations for a chipper for B2601? #5
Maybe it depend on how much time you anticipate taking to removing the trees based on the size of the trees and your time working at it. If you buy a chipper sized to fit your tractor, it could take quite a long time......because ....sawing and stacking and hauling chips is a lot of labor. Spread over 6 - 12 months you probably could get 'er done.
Cheers,
Mike
   / Any recommendations for a chipper for B2601? #6
we use a Woodmaxx manual feed and love it. No issues and in our 4th year with it. When we get a decent pile we chip it up. My wife is really happy to have the chips to use around everywhere
   / Any recommendations for a chipper for B2601? #7
With that many trees to chip even over a year, you’ll regret buying a chipper with manual feed. Let the chipper do the feed work. Get mechanical or hydraulic feed. I prefer hydraulic, provides much better control of feed rate.
   / Any recommendations for a chipper for B2601? #8
I have a Jinma 6in chipper for my B2620 (same some power/size as the 2601) and I don't really use it. I hate burn piles too but have gone back to them, its just not enough power to really chip up trees unless they are 3-4in and pretty straight.
I would suggest investing in a grapple and piling up branches/logs, then rent a commercial chipper once or twice.
If you're still set on a chipper the hyd. feed woodmax seems to be a pretty good product.
   / Any recommendations for a chipper for B2601? #9
I recently got the wood ax’s 8 inch hydraulic feed chipper. Great machine. Usually use on 40 horse pto but have used on 2601. Worked fine but I did slow down the feed rate. The hydraulic is a must for the 2601 in my opinion. Need to slow it down so I don’t work tractor too hard. But I have chipped 5 inch hardwood but as I said I did slow the feed rate down. With a hydraulic feed I just get it started walk away and get the next branch ready. 3200 shipped to my door.
   / Any recommendations for a chipper for B2601? #10
What he said. I had a stand alone chipper that would do 3 1/2" limbs. It was a PITA. I got a grapple and sold the chipper...took a heck of a loss on it but glad to get rid of it. Chipping is a lot of work and the small units are slow. Burn piles are easy if you need to burn the waste but I use some for critter habitat.
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51244)
UNUSED TOPCAT...
Land Honor Skid Steer 3 pt Adapter (A50515)
Land Honor Skid...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
SET OF (2) UTV TIRES, 215/65-14 (A51244)
SET OF (2) UTV...
