Any pricing yet on the new E tractors?
   / Any pricing yet on the new E tractors? #81
I was listening to Shaun Haney on www.RealAgriculture.com and he was doing reports from the giant Agritechnica show in Germany. He said at the last show before covid cancelled it out last year, all the manufacturers were showing off their electric dreams, like John Deere had a bunch of fake electric tractors with no motors or batteries in them because they didn't even have the technology yet.
He said this year there was none of that. He said it was all new diesel powered tractors and their focus has shifted towards adding new tech to the tractors such as automation instead of repowering them.
Seems to be the way many are heading now. The dream is over
   / Any pricing yet on the new E tractors? #83
I just read in Today's Trucking the big electric class 8 truck builders are starting to lay off workers. Another sign? LOL
   / Any pricing yet on the new E tractors? #84
I can tell you all with absolute certainty, when they will no longer sell me gas or diesel, I will go back to horse and buggy.
I'm lucky enough to be in an area I can still get everything I need to live within the distance I can travel by horse.
   / Any pricing yet on the new E tractors? #85
Yes, but what will deliver the goods to those local locations ? There's the real problem.
   / Any pricing yet on the new E tractors? #86
All the big mega fleets that are on board with the governments stupid agendas.
They can play with their electric and hydrogen junk. Not me. LOL
   / Any pricing yet on the new E tractors? #87
Recently 3884 dealerships from all brands of vehicles sent a letter to the white house saying its gone to far. People aren't buying electric vehicles. So there is hope. Hopefully
   / Any pricing yet on the new E tractors? #88
Just a few thoughts from someone who actually has experience with EVs... Five so far (2 plug-in hybrid, 3 fully electric). I would really like an electric tractor for my own use, mainly because mine is noisy as hell and I just finished rebuilding the engine! There are definitely use cases where electric tractors make a lot of sense, while there are others where it's a terrible idea. There's a lot of myths on electrification from both sides of the issue, so I wanted to drop by with my engineer mindset and personal experience to correct a few...
Some arguments for electrifying tractors:
1) Lower maintenance costs. There's simply far fewer moving parts. Engines have pistons, connecting rods, crankshafts, camshafts, lifters, pushrods, valves, carbs/fuel injectors, fuel and oil systems. And then there's transmissions, differentials, etc to get power to the wheels. And then there's shafts, gears, belts, etc getting power to where it's finally used. All of those parts wear, most of them require lubrication, and the vibration of an engine causes wear over time as well.
2) The additional weight of batteries can be very helpful for tractors, especially if it's done in such a way that at least some of the extra weight can be useful for balance as well. For example, if you're using a front end loader, where you're normally going to have some weight added to the rear of the tractor, instead of a weight bucket, make a 3-point aux battery pack instead. That would also largely ameliorate any charging difficulties - When the aux battery is depleted, drop it and pick up a freshly charged one.
3) Electrifying attachments as close to the point the power is needed can result in far lower mechanical losses in addition to lower maintenance costs mentioned above. FWIW, I believe that a successful electric tractor still needs a standard mechanical PTO, hydraulic system, etc to retain compatibility with existing mechanically driven attachments.
Some arguments against:
A) Tractors run at a relatively constant power load for long periods of time and will gain little to no efficiency from regenerative braking the way cars do, because cars are always stopping and starting.
B) Access to charging might be more difficult - This is a spot where the use cases are important.
Some things that should be done to make electrified tractors successful:
I) Battery life must be excellent. To achieve this, a good Battery Management System with liquid temperature control is important.
II) User interface must be designed to give proper warnings when battery level is getting low so that the machine can be driven to a spot where the battery can be swapped and/or charged. It should also have good power consumption meters so that the user can plan ahead.
III) The industry must use existing EV standards, and learn from the automotive industry, or they're going to have a rough go of it.
Use cases where electrification makes sense:
a) Home users who aren't using the machine every day and may even have long pauses in between uses. No use letting an engine rust. These users also would generally have the lowest demand for runtime. I'm in this group.
b) Farm use where there is daily downtime that can be used for charging, but enough daily use that a faster charging station and/or additional batteries (like the 3-point battery pack mentioned above, or a forklift-style battery swapping machine) are a worthwhile investment to take advantage of some of the other advantages of electrification
Use cases where electrification does not make sense: Any operation that needs 24/7 runtime (like giant farms using "combine cowboys" for 24-hour harvests) or is geographically large enough that they transport equipment on a semi trailer to the point of use. These *could* be done, but would require additional investment in large mobile batteries and/or battery swap stations and/or charging equipment. It could be done, but if it is it should be the last thing that gets done.
On to some replies:
I remember 40 ? Years ago GE had an electric garden tractor size lawnmower. It must have been battery powered, idk and it didn't matter to me. It was just as stupid to me as a little kid as I think it is today. 😆
I know a guy who has one, and loves it. It's actually a pretty good design. I don't think it sold particularly well or for particularly long, and I think only a few thousand were built but even today they have quite a following and a lot of them are still in use.
It would be something if the battery would even last 10 years
I don't know how long it takes to charge but say you get farmers
in the same area with 20 tractors what will happen to the electric
company will the power lines still be up???
EV's are really a JOKE! They cost more than a gas car and the
electric IHMO is not that much cheaper driving than a gas and
the emissions are not less because of what is used to produce
the power the ev. Compare the cost of the ev + hookup etc and
then a gas car in the long run I can't see how an ev is better and
with an ev you are restricts to where you can go!
The battery on my car is supposed to go 750,000 miles before it gets down to 80% of original capacity. I'll probably be dead by then. Batteries simply don't need to be changed out like that if they're properly designed using the correct materials and modern BMS.
The "grid won't support it" thing is largely BS. The grid supports a lot more than we use most of the day, because the grid has to support the large amount of power used in the evening (google "duck curve" for more info). Late at night and for a good chunk of the day, there's a lot of power available that isn't being used - That's why power companies have time-of-use plans to encourage users to flatten their duck curve.
Electric cars are now right about at the point where the cost to make them is on par with the cost of a gas car. In terms of operating them, your "humble opinion" on fueling costs doesn't match the facts - My wife's (gas) car costs 5-7 times as much in fuel per mile compared to my (electric) car's power usage. Emissions *are* less even though they're at the power company, even if the power company is 100% coal, because the power company's processes are more efficient than an internal combustion engine which is only 25-30% efficient. In addition, as the grid gets cleaner, all of the electric vehicles that fuel from it also get cleaner, whereas gas cars are the cleanest on the day you buy them and will never improve.
The "EV hookup" is not very expensive. My mother drives an EV and uses a charger she got with the car (free) and plugs it into a standard wall outlet. I use a level 2 charger that costs about $400-500. It's long since paid for itself. With the Tesla Supercharger network, I'm really not restricted in where I can go, and with the other manufacturers mostly having signed on to the NACS coalition now, this should be a complete non-issue for anyone in about 3 years.
And I've gotta say, I *LOVE* EV driving. That was a big surprise to me - I kinda got the first one just for the hell of it, but I quickly got hooked. It's smooth and quiet. I leave the house with a full "tank" every day. I never have to stop to fuel up unless I'm on a road trip. I never have to stand outside in the heat of summer or the cold of winter while fueling. The performance is fantastic. It's FUN! The environmental benefits or lack thereof don't even matter to me - I'll never go back to internal combustion. I've electrified everything except my tractor, my wife's car, and my airplane (which is a whole different can of worms).
Hope this is interesting to at least some of you. ;)
   / Any pricing yet on the new E tractors? #89
Dealers don't make money selling cars. They make money on maintenance - So they're very afraid of electric vehicles. People aren't buying electric vehicles *from dealers*. The Tesla Model Y is the top selling vehicle worldwide so far this year, so people are most certainly buying EVs.
   / Any pricing yet on the new E tractors? #90
I understand that and it took tesla 13 years to become profitable. And what most dont understand is that first month of profitability doesn't take away from the 13 years previous to that of straight losses. Do you think GM, Ford, and Chrysler can survive in that environment. Tesla has a brand to it that far exceeds any other EV manufacturer not to mention a CEOs name who most households have heard of. You can't say the same for the other manufacturers. Its precisely why they are mandating all new sales of EVs by whatever year it is. Mandating is just another word for (forcing) IF you owned GM would you want to continue to take losses on the bolt if you could just cut it and sell another SUV or truck. Pretty sure if you were the owner you would want to continue with what makes money. If people were adopting EVs then why mandate it?? Why not let the market drive what it wants. B?c the government knows the market will take to long in there eyes to move completely towards all EV's. Rivian is a dumpster fire so far. They will nee lots of money to stay alive. Ford just got over 9 Billion from the government. The governed brokered a deal between tesla and the bolt to use its charing network. Which is why they brought it back.
BTW dealers do make money selling cars. If they sold every car at a loss or breakeven. They would all go under.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2003 Big Tex 10PI...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
