Any pictures/plans of a firewood wagon built on hay wagon running gear?
   / Any pictures/plans of a firewood wagon built on hay wagon running gear? #21
I'm pretty late here and this isn't running gear but might be close enough. Not mine either - it's my neighbors
gg
   / Any pictures/plans of a firewood wagon built on hay wagon running gear? #22
From the website, bags are "breathable":
This 34.5" x 33" x 38.5" Type A Bulk Bag (FIBC) with an open top is ideal for storing and transporting dry goods for agriculture, landscaping, construction, and other industries. FIBC bulk bags are made from a thick, woven polypropylene with a UV enhanced finish. This bag holds approximately 1 cubic yard or up to 2,205 pounds of weight, and allows air and moisture to pass through the container.
Hoped to get upwards around 2 years ahead (plenty of time for drying) but brutal June/July heat stopped my splitting efforts cold! Figure around 4-5 cords ought to do it--we don't go through nearly as much as ya'll up north
Not that breathable.. you will have moldy firewood quickly unless it goes in those bags oven dry.
   / Any pictures/plans of a firewood wagon built on hay wagon running gear? #23
So I finally got around to building it. Works great. cant load as much as I want cause it gets so high, its a pain to load/unload. got 2 cord stacked on it so still better than doing it a pallet at a time!
My Neighbor redid his deck and gave me all the old deck boards:
used some left over shrink wrap from the boat to make a roof:
fill it up in the wood yard
pull it to the boiler
Hey All,
I know that I haven't commented here since I started this thread....but some really cool ideas have come in!
I haven't made anything yet but I like Gordon Gould's neighbour's rig and also Saint18z.
Keep showing us what you got...Dutchy
   / Any pictures/plans of a firewood wagon built on hay wagon running gear? #25
Interesting idea to put your wood pile on wheels.
Fairly regular, I see old untitled trailers go reasonably cheap at local auctions.
This could be a good re-use for them.
At the end of the day...wondering if this would be any benefit over simply loading up IBC totes with firewood and moving with a set of forks.
Have to think about the pros and cons of each...
   / Any pictures/plans of a firewood wagon built on hay wagon running gear? #26
I used a similar running gear set up for a couple years. Great for housing wood next to my outdoor wood boiler. It was a little cumbersome for my small tractor so I sold it and went with a 4 horse trailer. Used that for 9 years before finally moving on from burning wood.
   / Any pictures/plans of a firewood wagon built on hay wagon running gear? #27
I found an old John Deere Running gear and used fiberglas I-beams (local fencing guy has them for sale) -- and put sides as shown on them. I use IBC totes for firewood storage. The side rail is removable so that the totes slide in from the left side and sit directly on the large I-beams. This wagon also doubles as a good hayride wagon -- put the side rail back on and the kids sit on it.
   / Any pictures/plans of a firewood wagon built on hay wagon running gear? #28
I made this hay rack just for moving my wood from the landing down to my garage. My brother in law some times borrows it for doing hay. It also a 8 ton running gear, E-Z Trail.
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
JOHN DEERE 7210R LOT NUMBER 263 (A53084)
JOHN DEERE 7210R...
