Rake Any Other Use for Pine Needle Rake Before I Sell It?
   / Any Other Use for Pine Needle Rake Before I Sell It? #1
robertm
Northern Illinois
Kubota BX2660
So, I have a new pine needle rake that I never really used since I modified my landscape. Is there any other use for it I should consider before getting rid if it? Looks like one of those "gotta have another purpose" implements.
   / Any Other Use for Pine Needle Rake Before I Sell It? #2
The week after you sell it you will find a use for it
   / Any Other Use for Pine Needle Rake Before I Sell It? #3
Will it work for dethatching your lawn? Have a picture? Jon
   / Any Other Use for Pine Needle Rake Before I Sell It? #4
Do you have a pine needle rake that is used to windrow them for baling?
Tractor Tools DirectMolon TX-P78 Pine/Straw Belt Power Rake
Or do you have a pine needle rake that just collects them in a pile?
Pine Needle Rakes | Pine Straw Rakes | Prepare Pine Needles For Baling with the Everything Attachments Pine Needle Rake 72" Length
   / Any Other Use for Pine Needle Rake Before I Sell It? #5
I have used my original rake enough that it is finally worn out. I find it a great tool for smoothing, covering grass seed and the normal clean up work where a landscape rake is too aggressive.
   / Any Other Use for Pine Needle Rake Before I Sell It? #6
I use mine when seeding a new lawn. After the seed has been spread use the rake to lightly scratch it into the soil. Has worked well for me getting a good germination.
I have the EA rake, not the fancy windrow machine. I have an estate rake that dethatches like a dream, and windrows in the process. Thus, the need to get rid of the EA rake. I used it to clean up under a few hundred feet of spruce, then reseed and cleanup. Now, the rake sits.
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
Case IH 7120 Combine (A50514)
Case IH 7120...
