Rake Any Other Use for Pine Needle Rake Before I Sell It?
   / Any Other Use for Pine Needle Rake Before I Sell It? #1
robertm
Veteran Member
Northern Illinois
Kubota BX2660
So, I have a new pine needle rake that I never really used since I modified my landscape. Is there any other use for it I should consider before getting rid if it? Looks like one of those "gotta have another purpose" implements.
   / Any Other Use for Pine Needle Rake Before I Sell It? #2
The week after you sell it you will find a use for it
   / Any Other Use for Pine Needle Rake Before I Sell It? #3
Will it work for dethatching your lawn? Have a picture? Jon
   / Any Other Use for Pine Needle Rake Before I Sell It? #4
Do you have a pine needle rake that is used to windrow them for baling?
Tractor Tools DirectMolon TX-P78 Pine/Straw Belt Power Rake
Or do you have a pine needle rake that just collects them in a pile?
Pine Needle Rakes | Pine Straw Rakes | Prepare Pine Needles For Baling with the Everything Attachments Pine Needle Rake 72" Length
   / Any Other Use for Pine Needle Rake Before I Sell It? #5
I have used my original rake enough that it is finally worn out. I find it a great tool for smoothing, covering grass seed and the normal clean up work where a landscape rake is too aggressive.
   / Any Other Use for Pine Needle Rake Before I Sell It? #6
I use mine when seeding a new lawn. After the seed has been spread use the rake to lightly scratch it into the soil. Has worked well for me getting a good germination.
I have the EA rake, not the fancy windrow machine. I have an estate rake that dethatches like a dream, and windrows in the process. Thus, the need to get rid of the EA rake. I used it to clean up under a few hundred feet of spruce, then reseed and cleanup. Now, the rake sits.
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
International 1066 2wd tractor (A52128)
International 1066...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
(4) 16' Tarter Pipe Gates (A50515)
(4) 16' Tarter...
