Any one with experience with monolithic cement slabs or/and radient heated cement
   / Any one with experience with monolithic cement slabs or/and radient heated cement #1
kutter52
Cranberry Twp, PA
Toyota
I'm building a 24 x 36 garage in western PA. It gets pretty cold here so I want to insulate it and heat it economically. My plan is to wind about 1000 feet of PEX 1/2 tubing logically over the mesh prior to the cement pour. I'll using 4 circuits at around 225 feet a piece and entering & exiting the slab in one corner where my boiler will sit. Now it looks like my preferred builder wants to save me some money by using a floating "one pour" single pad where the footer is poured right with it but well above the frost line. He said about 18" thick with rebar in it around the perimeter where the slab will be a more conventional 4" thick over crushed limestone. Now I understand it is a good idea to insulate the slab by pouring on an inch or 2 of high density polystyrene foam which has a compressive strength of about 25 lbs per sq in. I wonder how much heat I will lose by convection into the footer which I don't think wold be a good idea to pour over polystyrene.
Does anyone have any insight for me?
Kutter52
   / Any one with experience with monolithic cement slabs or/and radient heated cement #2
   / Any one with experience with monolithic cement slabs or/and radient heated cement #3
Welcome to TBN! :thumbsup:
   / Any one with experience with monolithic cement slabs or/and radient heated cement #4
Doing a monolithic placement is done a lot, also to do it in a continuous pour. The most important thing is control joints. Next is compaction of the subgrade. Joints need to be cut to 1/4-1/3 of the slab thickness and not exceed 12 X 12 feet pattern. DO NOT let them talk you into saw cutting the next morning as cracks are already started by then. Yes, all concrete cracks, you want it to crack where you want it not a random pattern. Either trowel in the joints or saw cut as soon as the finisher is done. Forget about wire mesh and use fibered concrete instead. Mesh never gets placed in the proper level in the slab due to walking on it. If you insulate under the slab for your PN temps I would use 4" of polyisocyanurate or urethane. It will carry more loads and better R factor. If heating economics is your goal too little insulation is as bad as no insulation. Also then you need to insulate the footing walls before back filling. Glue it on with asphalt cement or you are wasting your money on it.
I just did a mono foundation/slab 12' X 30' 4 weeks ago. No cracks. We do not have a frost problem here so that was not a problem so I left out the rebar on the footer. Are you sure 18" gets you out of the frost heave zone?
My dialog is based on the latest recommendations from the American Concrete Institute. I was a member back when I was a QC Manager.
Ron
   / Any one with experience with monolithic cement slabs or/and radient heated cement #5
I've got a 12 X 36 "addition" on the lower floor. Slab on grade, "Alaskan" style ;-) But I did dig a four foot trench and filled it with stone to assure drainage.
The pex went into the pour located on the wire grid. ( I don't give rebar any credit at preventing cracks, It only holds the pieces together after)_
Rigid foam went down over the hard tamped base (key detail, Tamp wet, then tamp some more) Just stay a foot back from the perimeter. The concrete will act as it's own barrier. But do insulate outside the footer! In fact, I did a "skirting" that extends out 2 feet about 4 inches down. enough to cover, and I drive the tractor over it from time to time clearing snow. No troubles
Hot water is circulated from the furnace.
I did a "thin slab" on the kitchen addition. No insulation under, but it has a traditional tile and stone tile surface.
Both systems work EXCELLENT.
eta
Frost heaving needs two things,
Water and freezing temperatures. take away either, and you can have no issues.
I go for the dug trench, filled with draining stone to keep the water out, then do a bit of insulation .. 1 inch or two of blue board.
   / Any one with experience with monolithic cement slabs or/and radient heated cement #6
In northern Wisconsin we get plenty of frost and everyone uses the floating slab for garages, the only time a frost wall is used is on an attached garage. Generally all we do here is remove the top soil and haul in a good fill of sand or a good gravel then pour on that. 2 inch foam is the norm for insulation under slab. Usually a 4 inch slab with 12" around the edges
   / Any one with experience with monolithic cement slabs or/and radient heated cement #7
Aa 4" slab will crack. I built a garage in northern Alberta in '99. The slab was 22x26 with a knee wall all around. Similar to a vertical mirror image of what you are building. My slab was a minimum of 5" at its thinnest.
Before the pour I tamped(damp not wet), then tamped again. Then I tamped and tamped again. I built a rebar mat tying in the knee wall to the slab. The rebar was placed in a grid on about 12" grid.
In 2010 I moved to where I am now. After 11yrs there were no cracks. I figure there are 3 reasons why not. We had winter temps regularly down to -40F. Summer temps up to about 90F. The slab was strong enough to put my 6500lb diesel truck on with zero issues.
1- well tamped soil. I can't stress this enough.
2- lots of rebar to help strengthen the pad
3-not the usual 4" slab. Most 4" slabs only the width of a 2x4(actually only 3-1/2".)My slab was thicker than most.
I didn't have the in floor heat like you are putting in. In hindsight I probably would have. My concern at the time was cracking concrete creating a leak. Buddies slabs all had cracks big enough to drop a wrench into.
I plan to buy a small slant fin cast iron tank less boiler fired W gas. My tubes will be only 2 to 3 in down so I 'm scared to death to saw cut to promote cracks. One, I don't want to cut my tubing and two, cracks will separate and possibly break my tubing. I believe my guy said he uses fiber to reinforce and will put the screen in for me to tie my tubing to. I am greatly concerned about the height of the screen so I will use bricks to support it in many places. I almost think it might be a good idea to put a screen on top of my tubing. It would ensure my tubes stayed down and better control their depth.
18 in is well above the frost line as we have 36 in to the frost line. My garage may be floating around my back yard. I don't want it cracking apart though so some serious rebar usage is no doubt paramount.
   / Any one with experience with monolithic cement slabs or/and radient heated cement #10
There is really no way that rebar can prevent a slab from cracking.
It can only hold the pieces close together after the cracks form.
Slabs crack in bending, the rebar is placed in the neutral axis. There is no "tension" on the rebar until AFTER a crack is formed.
But ti is nice not to see gaping cracks caused by poor preparation.
ETA
Some will contend that insulating the slab just incourages freezing. That is, the heat loss down into the ground from the heated slab serves to keep the sub soil from freezing.
Insulating the perimeter is probably more significant than the slab it's self. If the base material is kept dry, heat transfer can be minimal.
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
2000 Sterling L9513 Winch Truck (A55218)
2000 Sterling...
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
