Any one seen a drone?
   / Any one seen a drone? #102
Would those paint ball guns be powerful enough to hit one of those things?? No holes but a whole lot of wild paint if they could hit one.
   / Any one seen a drone? #103
Have you checked with your neighbors? May want to try these guys too - PHPRC Landing Page - an RC plane club local to your area.
If this is a simple RC aircraft, the pilot is going to be very close by (they need to see it to fly it).
You are right about being able to see it fly, it is a requirement of the FAA. I am fairly certain the drone I see is more in line with a government or military design. Hopefully the FAA will find out.
   / Any one seen a drone? #105
How about a pix of this darn thing!
How can you tell the size of any aircraft without a frame of reference? How far away is it? downrange and at what azimuth and elevation?Can you hear its engine/s? Have you tried to use the 2 simultaneous observers spaced apart method to determine azimuth and elevation? It may not be near as large as you think it is, just closer to you than you realize. I postulate that it is impossible to determine the size of any aerial object with just one observer and no other clues or frame of reference. The drone could be 6 inches long or 60 feet long, There is no way to know.
James K0UA
   / Any one seen a drone? #106
CNN Pentagon Correspondent Barbara Starr:
It looks like a bat, sweeping, turning. But it’s actually the new super-secret Air Force stealth drone.
CNN has learned this unmanned spy plane is designed to fly for up to 24 hours behind enemy lines in countries like North Korea, Iran, and Syria.
Military sources tell CNN it will give the United States a critical stealth advantage to spy on countries that have strong air defense systems able to shoot down more conventional aircraft.
The drone, believed to be called the RQ-180, was first revealed by the magazine Aviation Week and Space Technology in a lengthy article co-authored by Amy Butler and Bill Sweetman, both long time experts in classified military stealth technology.
The program is so classified the Air Force would not confirm its existence to CNN or Aviation Week.
But several U.S. officials told CNN its capabilities are a top intelligence gathering priority– especially after a less sophisticated stealth drone went down in Iran in 2012.
The key, Butler said, is the drone’s ability to fly long distance and stay aloft for 24 hours in a stealthy manner.
"This aircraft will be able to penetrate that border and conduct operations in and around an enemy airspace without being targeted," Butler told CNN.
It’s so secret the drone is believed to be at a hangar at Area 51 - the Air Force's highly secure flight test center in Nevada.
The drone may be able to fly as high as 11 miles. The requirement for an asset that is stealthy, can fly at high altitude and conduct intelligence, surveillance and reconnaissance is a crucial priority for the military and the intelligence community.
In several countries, air defenses have improved significantly in recent years making it difficult if not impossible for U.S. assets to gather information.
The drone’s ability to stay up for 24 hours will also give it a key advantage over satellites which often pass by a target intermittently and are subject to be being detected.
Butler said the shape of the drone means enemy radars can't easily see the drone as heat it throws off is shielded so radars can’t pick it up.
“This aircraft is designed to evade both those thermal sensor, those radar sensors, and other sensors that look for aircraft. So it might not be invisible to radar, but you might not be able to target it and shoot it down.”
Butler suggested the drone may even be able to carry sensors that can listen to cell phone calls and any “activities on enemy frequency, radar activities, that sort of thing.”
Although it’s not confirmed, the magazine suggested the drone could be operating as soon as 2015.
Post by: CNN Pentagon Correspondent Barbara Starr
Filed under: drones
   / Any one seen a drone? #107
Even if you own the air space, the worst you could claim is trespass...not likely to get you off scott free.
Depends on your lawyer.
"Your honor. My client issued three verbal orders to the drone to stop. As the drone was within my client's curtilege, and he was in fear for his life that the drone was armed, he shot to kill. Clearly a justifiable case of self-defense. I ask that all charges against my client be dropped."
   / Any one seen a drone? #109
Sorry, you are mistaken... I definitely know what 6 inches looks like. However, I did try your two person, simultaneously, shooting an azimuth and vector bs and to my dismay, 6 inches turned out to be only four. Post back when you are coherent.
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
10 Ft Fork extensions (A50322)
10 Ft Fork...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
