Any one know about car type ACs?
   / Any one know about car type ACs? #11
I think your biggest problem would be finding a junkyard a/c unit you could use that was in good enough shape to bring back to life.
You would need the system to use r134 unless you plan on going to mexico to get some r12.
some things you would neeed,
compressor, acumulator, lines, orfice, condensor, control unit, pressure switches, oil and leak die.
here is a short description,
(1)A/C Compressor(2)A/C Condenser(3)A/C Evaporator(4)A/C Accumulator(5)A/C Low Pressure Switch(6)Dessicant Bag(7)Oil Bleed Hole(8)A/C Condenser Orifice
The cycling clutch orifice tube (CCOT) refrigerant system cycles a compressor (1) on and off in order to maintain the desired cooling. This cycling also prevents evaporator freeze-up. The temperature selector on the control assembly maintains comfort in the passenger compartment comfort.
A switch that senses low side pressure as an indicator of the evaporator pressure controls the refrigeration cycle, or the on and off operation of the compressor. The cycling pressure switch is the freeze protection device in the system. The switch also senses refrigerant pressure on the suction side of the system. This switch is located on a standard service low-side fitting. With air temperatures of 16-26ーC (60-80ーF), the increased pressures within the charged air conditioning system closes the contacts of the pressure switch.
When an air conditioning mode is selected, the compressor clutch coil receives electrical energy. As the compressor reduces the evaporator pressure to approximately 175 kPa (25 psi), the pressure switch opens, de-energizing the compressor clutch. The system moves towards equalization and the pressure reaches approximately 315 kPa (46 psi). Then, the pressure switch contacts close, telling the PCM to recognize the clutch relay. The cycling continues and maintains the evaporator surface temperature at approximately 7ーC (45ーF) depending on ambient and relative humidity. Higher ambient temperature and higher humidity equal higher discharge temperature.
Some slight increases and decreases of engine speed/power may occur under certain conditions, due to the cycling. This is normal. The system cycles in order to maintain maximum cooling, without evaporator freeze-up.
Additional compressor protection results from the operating characteristics of the low-side cycling pressure system. If a massive discharge occurs in the low side of the system, or the orifice tube becomes plugged, the contacts of the pressure switch may not close due to insufficient low-side pressures. If there is a low charge, insufficient cooling accompanied by rapid compressor clutch cycling is noticeable at high air temperatures.
When the engine is OFF while the air conditioning system is operating, the refrigerant in the system flows from the high-pressure side of the expansion tube (orifice) to the low pressure side until the pressure moves towards equalization. This may be detected as a hissing sound for 30-60 seconds. The hissing is normal.
The air conditioning systems available for the vehicle are the following:
?nbsp;C60 Front Manual Controls, HVAC System
?nbsp;C69 Rear, HVAC System​
   / Any one know about car type ACs? #12
Any thoughts of using one of the roof mounted (RV) A/C units?
Mounting the compressor to the engine maybe the toughest part.
You can buy custom made A/C hoses from most larger suppliers.
Last, a super-duty cage, or box, to protect the roof mounted unit!!
Any A/C system open,or leaked empty will draw moisture.
This moisture will change into an acid if not completely removed.
The acid will destroy the A/C unit from the inside!
Good luck!
   / Any one know about car type ACs? #13
Anything is possible given time and money.....
Maybe if you could find an RV roof AC unit that still worked (no gas lines open to the atmosphere and still capable of cooling), if that that unit has modern freon that you can replace from today's parts stores, if you can bring yourself up to speed on all the compenents and their relationships, and you can then mount the compressor and condensor in a place that makes sense and provides the right air cooling and rotational speed, then maybe you might be on to something.
I respect everyone here who makes things out of stuff. It is not always about the most cost effective way but it is all still pretty 'cool'....
For my .02, I think I would also investigate a cheapo house window airconditioner and what it would take to make that run on your tractor along with sealing up the cab as we know a house AC is much smaller than a vehicle unit. Maybe they are too fragile and maybe the startup current is to great for big inverters but maybe???
Or find a used tractor place and look for an existing solution??
I sometimes work with AC units that were designed for trains, buses, etc. The condensor units have DC electric fans that change velocity as the pressure changes. The evaporator unit (inside the vehicle) is very simple with a DC fan behind the coil and a simple high low fan and hot/cold dial knob. The auto style compressor is run off a belt to the main engine with a standard electric clutch assy. I think they are made by Konvectra (sp?) and my usage is in R&D mobile stuff. Crazy expensive new, so don't look to buy one from the factory... :)
Simple systems like this still exist and are made but moving that to a tractor might be a non-trivial task.
   / Any one know about car type ACs? #14
We seem to be overlooking the fact that he is on an open tractor with just a sun shade roof!
Air conditioners circulate the same air through the evaporator coils over and over to dehumidify and cool the air. A single pass is going to be MUCH LESS EFFECTIVE. If the RH (relative humidity) is low then there are lots of possibilities, including a "swamp" cooler approach. With low RH a wet bandana or a misting system would work miracles. With high RH you can forget misting, cool handkerchiefs and such.
The problem is the OPEN WORK STATION. Running single pass air onto you in an open tractor will not do much, certainly a lousy return for the effort invested. Want to test this? Drive 60-70 MPH with all your windows open and ask the back seat passengers how cool the A/C feels. Even front seat passengers may not be helped noticeably.
I once built a prototype hot/cold therapy machine, originally intended for use on thoroughbred horses but later marketed to the San Diego Chargers football team and as a medial apparatus for both hot and cold therapy on human patients.
Your comfort depends on many factors. Net heat loss/gain can be a large factor. If you sit down on a cool concrete bench even though the air may be 100F it will cool you off by conduction. The concrete can take up considerable heat. No, I don't recommend a concrete seat for the tractor.
Here is the deal. A small refrigeration compressor is plumbed to neoprene tubing for the evaporator instead of copper tubing in a finned heat exchanger (evaporator.) The neoprene tubing is glued to neoprene foam "wet suit" material in a pattern like in-floor hydronic tubing is put in a slab. This is fashioned into seat covers for the tractor. When you sit on the seat you will loose body heat into the seat. and it will cool your entire body due to the effect of blood flow. If you want to do more you can make up a couple "arm covers" like shirt sleeves which can wrap around your upper arms and fasten with Velcro. This can suck a lot of heat out of your body. You will have to be careful to not overdo it and chill yourself too much.
I personally think the "cool seat" would do enough and would be more convenient for getting in and out of the tractor while working. Arm and or leg covers would be fine for long sessions as adjuncts to the cool seat. They would allow more surface to be involved so cooling could be more moderate for the same net effect but if you have to get on and off a lot it would be a bit of a nuisance but not too bad with Velcro fastenings.
Do exercise caution as this is a very effective cooling system and you can chill your flesh too much. When I built the prototypes of this system I designed and built a thermostat that operated off the skin temperature of the patient and cycled the unit on and off to maintain that temp.
If you build this system, consider using a reversible heat pump so you can heat the seat in winter with very little extra cost.
Pat
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
