Any oil analysis to share?
   / Any oil analysis to share? #1
snoboy
Washington
04' Branson 4020
I can't believe I'm the only guy to do a UOA on his tractor anybody else get their oil sampled?
snoboy
   / Any oil analysis to share? #2
ooooohhhhhh, here it comes...... this should open up some "discussion" /forums/images/graemlins/grin.gif
In answer to your question: I do not get my oil sampled.
Well thank goodness, I posted the sample a while back and no replies, Actually I posted a few items and got no replies. I was begining to think a boycott snoboy had taken place.
OK so you don't get your oil sampled. WHY THE HECK NOT! Just kidding. Thanks for the reply. /forums/images/graemlins/grin.gif
snoboy
   / Any oil analysis to share? #4
Dad always told me the quickest way to start an argument was to bring up politics or religion. I think he left out lube choice. That seems to be a hot button w/ a lot of folks.
   / Any oil analysis to share? #5
I work for the fleet department for a local county government and we sample all the compartments of heavy equipment at every service. We have caught many minor problems before they turned in to larger problems. I do not have enough hours on my tractor yet to service it but I will sample all compartments when I do the first service. Cheap $25 insurance.
   / Any oil analysis to share? #6
I have a 1978 Kubota B7100 and a 1997 Dodge 2500 with a Cummins. I get my oil tested at Blackstone yearly on each one. On the Cummins I found out that my oil filter had gone to bypass and the air filter was letting dirt through. A lot of people with diesel pickups test their's.
   / Any oil analysis to share? #7
Snoboy,
I send the tractor and truck oil off to Blackstone. The JD oil has only gone a couple times. The truck I send if I let the oil go longer than I have in the past. The last oil change on the truck was well around or under the milage I changed last time so I did not send out to be tested. I have run the oil to about 8,000 miles I think and Blackstone said to go to 10,000 and see what happens.
I don't want to go that high but at least I know it possible on the oil. I am using Shell 5w40 in the truck and the last oil change the tractor got the same oil.
I will send the tractor oil to be sampled again.
Later,
Dan
   / Any oil analysis to share? #9
The way you guys are using oil analysis is really the way to do it. It doesn't have to get technical and way in depth. If your oil is doing it's job that's great. If you change at 5k, 7500k, 10k, etc. you just need an oil that will perform to your standards. Getting an oil that is still up on all standards does a person no good if they are just draining it out. Way too many times these discussions go south because they get into what could be better instead of just what works in your situation.
Very well said cowboydoc.
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
Electric Mobility Scooter (A54815)
Electric Mobility...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
