Any news on gas engine CUTS?
Status
Not open for further replies.
   / Any news on gas engine CUTS? #501
R1 tread is the best for traction... You can have all the power in the world.. If you can't plant it to the ground, it's no good
   / Any news on gas engine CUTS? #502
Yep, pretty much agree with all of that.
So you agree that starting and stopping loaded is harder on an engine than a fixed continuous load? But you still say a lift is a light duty job when it is a constantly starting and stopping application with a heavy weight machine usually over 11,000 LBS of machine or more and then weight is added to it continuously then repeated over and over again with the RPM going up/down and everyplace in between! Actually it sounds a lot like doing a day of loader work with a tractor to me the difference being that we wont all hammer the **** out of our tractor but those warehouse lift drivers are basically nuts and have no respect for those machines its abuse no doubt about it and its a heavy use application no matter how you slice it!
My guess is if you took an engine from a lift that has spent its life in a big warehouse and installed it in a scut it would think it was on vacation!!:laughing:
   / Any news on gas engine CUTS? #503
Sure, but not all folks putter around with the CUT or SCUT, so manufacturers have to build them to be on the heavy/strong/durable side if they want to avoid failures and warranty claims. Modern diesels are also a lot better about wet stacking than older designs.
As I've said all along, a manufacturer could make a DI gasser engine for SCUTs and CUTs that would work fine, but it likely wouldn't increase their sales at all, so it would be wasted development money on their part. Sure, they would be able to offer a somewhat less expensive option to customers (the exact amount is open to debate), but those same folks would be buying a tractor either way in most cases. I just can't see that making any business sense to them, and it's almost certainly why they aren't offered now.
On your first point, I do know that different levels of SCUTS/CUTS have duty cycles and planned lifespans that might be less than most people think. A ladder frame SCUT with an aluminum rear transaxle and a plastic fan underneath to keep it cool was never meant to do 5000 hours of sustained high duty-cycle usage. We see an average of 50 hours/year on the 25HP and under machines. It takes 20 years to get 1000 hours on one, so there is no reason from a manufacturers perspective to build this machine to run 5000 hours. Yes, they will run 5000 hours with a lot of care and gentle usage, but they aren't made to do that. Note, I am not naming brands, even the well respected leader of the SCUT market knows these will see less duty cycle and less yearly hours and builds them accordingly. This might be a place for a gas engine. As we go up in HP, we see guys sometimes doing 500 hours a year, and the real ag guys can do 1000 hours a year. If you take a typical CUT and run it 1000 hours a year, it'll see some shop time. Do this with a real dedicated (expensive) piece of ag or construction equipment and 1000 hours is nothing. I guess my point is that while these small tractors can do a ton of work and are occasionally worked very hard, let's not over estimate their duty cycle design.
On your second point, I could not have said it better. A manufacturer needs a reason to go through the R&D and to take a chance. If they are currently selling near capacity and the gas engine would only rob from the diesel sales, why do it. However, if only one manufacturer comes out with a nice gas tractor, it might be that they can do real well. There would be a small market for a gas SCUT, but they would not have a lot of competition.
   / Any news on gas engine CUTS? #504
I never said higher compression was better. You keep saying gasoline engines are just as durable as diesels. I'm telling you that with the same compression as diesels, they're not.
Eugene
Please tell use how or why that is a valid line of reasoning and pertinent to the conversation . Btw the DI gas in Mrs B&D's ride runs just fine at 11.6 to 1 on 87 octane.
The "high" compression ratio is all about increasing thermal efficiency on the power stroke . When throttled the compression ratio maybe as low as 4 to 1 when cruising. This is where a throttled spark ignition beats a diesel's thermal efficiency at part load.
Have you ever seen throttle blades outside the first stator blades on a stationary gas turbine engine ? They are there to improve part load thermal efficiency.
Why do you think higher compression is better? Are you aware of how the basic Otto cycle Brayton design operates . It's all about effective pressure under the curve on the power stroke vs the average pressure in the compression stroke. The engine works by heating and thus increasing combustion chamber pressure after the compression stroke. The delta T and thus the delta P is lower when the combustion chamber is hotter rather than cooler. A high compression ratio has already used power stroke energy to dump more heat into the combustion chamber with high compression vs low compression .why do you think intercoolers are used on reciprocating diesel and on gas turbines between the compressor stage and combustion chamber ? To improve thermal efficiency , reduce max combustion temps and increase max possible full rated power.
   / Any news on gas engine CUTS? #505
P
#1 we have all seen and heard the predictions of crude oil prices since the early 1970's as they roller coaster up and down. When prices are climbing the graphs show $200 a barrel in a few years. The. The price of crude slumps and the new graphs show $50 crude in the same time frame that $200 had been so somberly predicted in. The market and prices do not stay down or stay up, they swing.
#2 as for those using thier CUT and SCUT at full power for hundreds of hours per year. You know that is the exception rather than the rule so quit wasting you time .
Buickanddeere,
Your reasoning is just unbelievable in so many ways:
1. What possible value is 1970s or 1980s or 1990s oil patterns to the changes that started in oil and natural gas in 2003 in the U.S. and have altered EVERY 18 months since then. Your statements demonstrate you don't know the trending doubling each 18 months of oil reserves in the shales of the colorado/wyoming/ dakotas. And your statements also appear hollow as to the cost reductions developed since early 2013 and the retro applications developed in late 2014 and early this year. You're way out of touch with the trends of oil costing and present/future oil quality improvements, as well as the artificially created temporary oil demands of China from 2004 thru 2013.
The pricing swings NEVER exceeded 150.00 per barrel and currently you can acquire oil futures for year 2020 at less than 69.00 per barrel. Since 2013 Opec has been running scared because they know their grip on the oil market is rapidly disappearing.
By the way, pump pricing as of yesterday in our area of western wi was as follows:
Premium gas . . 3.29
Premium diesel . . 2.59
Regular gas with ethanol . . 2.57
Regular gas no ethanol . . . 2.71
Regular road diesel . . . 2.54
Note: all diesel listed is road taxed and ultra low sulphur 15 ppm
#2 As for your original demeaning comments on older tractor buyers using 50 tp 100 yearly hours and light loads . . now suddenly you want to debate "hundreds of yearly hours with full loading" being the minority. ???? So exactly where do your numbers come from buick? Is that 150 yearly hours or 400 yearly hours? The point is . . you just keep making things up. Where are your facts?
   / Any news on gas engine CUTS? #506
   / Any news on gas engine CUTS? #507
One of the gaping holes that "gas engines for scuts and cuts" keeping talking about without reference . . Is what is needed in a gas engine to mimic the performance of diesel in a scut or cut tractor.
It will require high compression gas engines with clean burn characteristics. A high compression engine is typically defined as an above 9.1 compression ratio. 9.1 and below allows use of regular gas (preferably none ethanol). To attain both cleaner burning and higher compression ratio performance a non-ethanol octane of 90 or above is desired with even higher octane levels for cpmpression ratios above 12.
Failure to use a higher octane in a high compression engine will cause 2 things:
1. Decreased actual burning of the gas fuel = lower mileage/hours per gallon.
2. Increased unburned hydrocarbons and emission issues.
That means premium gas and premium gas pricing . . Current price in our area is $3.29.
My massey gc1715 duesel operates at a 22.5 compression ratio and I use premium diesel (including road tax) of $ 2.59 per gallon.
Now isn't it strange that gas proponents don't seem to mention this that the fuel costs of a yet to be developed gas scut/cut tractor engine would actually be considerably higher than diesel . . . not lower :)
   / Any news on gas engine CUTS? #508
I just bought hiway diesel at $2.16.
Eugene
You must be in the indiana/ohio area or the South. Very attractive pricing. And it will be declining further.
Do you know if what you got was premium or not (both are ultra low sulphur) . . but the premium diesel is just a nickel or a dime higher but has cleaners and increases mileage.
   / Any news on gas engine CUTS? #509
I'd expect to see spark ignition CUTs available when I start seeing spark ignition semis on the interstate.
One variable I'd like to see defined is fuel consumption per unit of work done.
An example would be how many "standard" square acres of grass a machine can mow on a gallon of fuel.
From personal experience - and I'll admit that I can't document it - it seems that I can cut twice as much grass with a diesel tractor compared to a gas one.
That means I can cut for twice as much between fuel stops, using diesel.
Or I can get an equal amount of cutting done with a fuel tank that's half the size.
   / Any news on gas engine CUTS? #510
I never would have thought I would see all the LNG class 8 trucks that I see. So who knows.
Status
2 Wheel Wagon / Cart (A50515)
2 Wheel Wagon /...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
John 4 x 4 cart (A50323)
John 4 x 4 cart...
Land Honor Portable Screener (A50514)
Land Honor...
