Any news on gas engine CUTS?
Status
Not open for further replies.
   / Any news on gas engine CUTS? #181
Why is it that when I point out you make a glaring mistake (like say I haven't posted something I have) you try to reverse it?
Your "theory" is wrong, and before you even stated it, I disproved it (you didn't read that either, evidently)....I countered what I knew you were going to say with actual facts, not wild theories.
You're saying diesel prices will stay high because refineries want to make more money, regardless of their cost to produce. That's a ridiculous statement considering what we've seen the last few months. We have proof, not wild theories, in the recent few months. Gas prices have been slashed nearly in half because their cost to produce dropped significantly. If your theory was valid, they wouldn't have lowered their prices, but they did.
Taxes are the big difference in price between gas and diesel? Are you sure of that? Do you even know what the tax differences are between the two? Approximately $.06 per gallon....that's it. Proof:
Motor Fuel Taxes
The refineries upgrades were paid off between 2009 and 2011? Oh wait, that's according to a model you claim, not actual proof, or facts. Funny, but ULSD wasn't finished being implemented until 2010, so how did they pay it off before, or immediately after making those changes? Don't bother trying, you can't answer that.
Diesel demand has been lower in the U.S. than in the rest of the world for a long time, so the rest of the world subsidized the upgrades needed for ULSD faster. Since 2004 the demand for diesel has grown roughly 30% in the U.S., but production has only increased about 15%. We call that economics....supply and demand. The refineries have had high demand, and increased operating expenses....those both lead to higher costs, but only temporarily. When they catch up to demand, and finish paying off the upgrades, diesel will be back to being lower than gasoline, just like it is in the rest of the world. We may not be on the same timeline as the rest of the world, but our math isn't any different than theirs, so the same thing will happen. Some light reading if you want some actual facts:
https://blog.gasbuddy.com/posts/Why-diesel-costs-more/1715-485481-832.aspx
A diesel Cruze costs less to purchase. Fuel costs will vary with the price of the fuel. Future service costs are still undetermined....we'll only know that after they get some years on them, but folks who actually understand modern DI engines have pointed out all the extra stuff on them that would be bad on a tractor, so it's still a pretty weak comparison.
The funny thing is that you're talking about light duty vehicle, and you may be one of the few people who think that applies to tractors. When I'm doing something as boring as mowing I'm running my tractor for hours and hours at PTO speed....not even remotely similar to how a true light duty work cycle would be.
Maybe you putter around with your machines, I do work with mine.
How is it that diesel prices at the pump have not fallen as low and as fast as gasoline prices as crude oil dropped.
The Cruze diesel is more expensive to purchase than the gas.
Even a low hour useage machine such as a CUT will use less $$$ per hour on gasoline than diesel . Due to gasoline being cheaper per btu at the pump than diesel. The DI gas also has much higher thermal efficiency that a carburated gas and now nearly matches the diesel's power out per btu in.
   / Any news on gas engine CUTS? #182
My co-worker has one of those problems and the Car's head gasket is also seeping. He jumped a fuel temperature sensor which tricks the ECM into extra fuel delivery .
It's a design defect in this case for sure and it looks like VW is at least doing something to help. Probably many more coming so I'm sure it will go down in history as an epic fail.
The older designs could get some big tuning gains fairly safely (they're mostly for econnomy, not performance) but the newer designs don't have as much margin I don't think. You're really opening yourself (in my opinion) to potential big expensive problems tuning these new engines.
I have Cosworth ARP racing studs holding my head down. If I had any more boost I'd be warping head and trashing head gaskets too.
   / Any news on gas engine CUTS? #184
SR
   / Any news on gas engine CUTS? #186
That's torque, not HP. 25 is 25 is 25 period.
Only on paper...in theory... as I'm sure you know....
A 25hp diesel will have more real-life, usable power than a 25hp gasser due to a diesel making its power at a lower rpm and making much more torque. Different engines will make their power in different rpm ranges depending on the application it is built for.
So in pracrice, 25hp is not 25hp is 25hp.
   / Any news on gas engine CUTS? #187
If both engines were dino tested to make 25 hp then they will perform equal work. Torque and rpm are interchangeable with gearing. My old MM gasser is red lined at 1275 rpm and has plenty of lugging ability. A modern gas engine could be optimized for tractor use. It's mostly a function of cam timing. Just my opinion.
   / Any news on gas engine CUTS? #188
So in practice, 25hp is not 25hp is 25hp.
Somebody posted one time a condensed article what range of efficiency of plain V belt drives can vary from the ideal to a worn over tightened belt on a worn set of pulleys. iirc something from the mid 95 ish % range down into the 60-70% range ???
   / Any news on gas engine CUTS? #189
Again, it's economics...supply and demand. The demand for diesel is greater than the supply, so the prices haven't fallen as much. They still have dropped a significant amount (roughly 25%), which continues to show the concept of refineries keeping prices high just to make more profit doesn't reflect reality.
Again, you keep saying this, and it's false. The best DI gas engines are better, but still a long ways from matching the best diesel engines. The best diesel engines are around 50% thermal efficiency (power output per btu in), and the best DI gassers are around 35% thermal efficiency. That gap (15%) has been pretty consistent over time, and there is no way around it. Gassers would have to see a 30% increase in efficiency to match the best diesel....not likely.
   / Any news on gas engine CUTS? #190
Nope.
Status
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2000 NEW HOLLAND LS180 WHEELED SKID STEER (A51242)
2000 NEW HOLLAND...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
UNUSED FUTURE QUICK ATTACH CURVED LOG GRABBER (A51244)
UNUSED FUTURE...
