Any New Holland engineers, mechanics on this site?
   / Any New Holland engineers, mechanics on this site? #1
goatman
southern ohio
NH TC 30
I have called 3 dealers and am told that the TC30 does not have a two piece wheel offered. No one can tell ne if the bolt pattern on the TC 30 is same or differnt than the TC 29 or Tc 33 that does offer two piece wheel.. Iam trying to get the rear wheels wider before I go up on my slanted pasture and bush hog.. Thanks in advance /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif
   / Any New Holland engineers, mechanics on this site? #2
All Class II NH compacts use the same rear axle shaft and lug bolts. This includes the TC30 and all configurations of the TC33. Therefore, any rear rim offered for one model would bolt up to the axle shaft on any other model. I believe all the fender clearances are the same, so the only consideration would be the loaded radius and drive ratios of the front/rear tire combo you end up with.
Rick B, Thanks for the info.. I don't want to change tire size just the rims.. If NH makes a split / two piece rim for the TC33 do you see any problems attaching to the TC 30.. Again thanks for your time... /forums/images/graemlins/smirk.gif
   / Any New Holland engineers, mechanics on this site? #4
All of the wheel rims for the class 2 compacts including the TC30 are one piece. New Holland does not offer a two piece rim for these tractors.
I drove by NH last night and your right the only tractor with the two piece rims were TC 35 and bigger.. This really sucks /forums/images/graemlins/mad.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif Guess I should have done little more research before buying...Guess I'll just have to extra carefull on my hill side , just wanted to make it harder to turn over..Thanks for the info...
   / Any New Holland engineers, mechanics on this site? #6
I remember a post a while back where someone put dual wheels on their tractor, That may be a solution for you.
   / Any New Holland engineers, mechanics on this site? #7
Does anyone make axle extensions? or wheel extensions for compacts? Of course this would probably turn into some kind of stress issue on the bearings.
Solo
   / Any New Holland engineers, mechanics on this site? #8
Try www.Unverferth.com for wheel spacers or axle estensions. If they do not have the propper size, try www.performancewheel.com or other large custom tire and wheel shop. Most any machine shop can also make a pair for reasonable cost.
The main advantage of duals is better floatation in soft ground, and while they will also improve stability, duals will add much more strain on axles and bearings than a 3" or 4" wheel spacer on each side.
Liquid filling helps a lot also.
Good Luck, Rip
2007 WESTERN STAR 4900 (A52472)
2007 WESTERN STAR...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
ITEM LOCATION (A53084)
2019 Snorkel S3226E (A50120)
2019 Snorkel...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
2025 John Deere 3025E (A50120)
2025 John Deere...
