Any install tips for a block heater on a SA424?
   / Any install tips for a block heater on a SA424? #1
ultrameta
Yanmar SA424
I just ordered the factory part, haven't received it yet. Just looking for any "been there, done that" tips.
   / Any install tips for a block heater on a SA424? #2
If it was me I would install a lower heater
hose heater, simple to install and very easy
to replace when it quits working
willy
   / Any install tips for a block heater on a SA424? #3
How hard it is to install depends on the model. Mine have all had a threaded plug in the engine casting where I put the block heater. Hopefully yours does too.
If so, then comes the problem of unscrewing a bore plug that has been corroded in place for years to decades. I am told by people not to try it with the engine cold. Run it until everything is warm and then make sure your tools fit so that you don't ruin the head of the plug. Go slow, tap on it, use a hand impact driver, and be willing to give it a break until later....use all the tricks you know and it will come out.
Then just clean up the threads and screw in the block heater. I use a teflon thread sealing paste. The block heaters are very durable. I don't think I've ever had to replace one that quit.
Don't forget to replace the antifreeze that ran out when you removed the original plug.
   / Any install tips for a block heater on a SA424? #4
Do not drill the bore plug to get it. There was an epic TBN post here a few years ago. I seem to recall that the cylinder sleeve wall is a lot closer to the back side of the plug than is expected. The heater installation job got a lot more complicated after that. But the OP was handy and got the motor back in it and running a few months later.
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
19009 (A48082)
19009 (A48082)
Aer Way Tillage Tool (A50514)
Aer Way Tillage...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
