Any input on the SLT1554???
   / Any input on the SLT1554??? #11
I am looking at purchasing the SLT1554. I have 3 acres of flat lawn to cut..
3 acres of flat lawn is the key right there. The 1554 would be perfect for this application if that's what you intend to do with this machine, aside from maybe pull a light cart, etc. The engine in this price segment is irrelevant. They're all good. The 1554 is even more perfect if you're terrain isn't real rough and bumpy. Rough terrain will tear this machine up trying to support a 54" deck. Also keep in mind to let this deck 'hang' while mowing, with the gauge wheels set to contact the ground ONLY on high spots.
Joel
   / Any input on the SLT1554??? #13
I have a 2005 SLT1554, I bought it in brand new sept 2005. This tractor is ok. if you are mowing 3 acres on flat ground , not to hilly.
I have a 54 inch deck. I currently have 832 hours on the machine. The rear end, transmission, the gears inside are well worn. The bull gear with the miter gear in them with that small shaft has worn out and messed up the main bull gear. Anyone can get parts for this tractor SLT1554 through partstree.com. almost total price for parts that are worn is $ 160.00. On the transmission the oil that it takes is 20w50. Can this oil be any manufactor ?
The engine still runs great. I change the oil ever 25-30 hours.
The mower deck, I go through spindles like crazy. I did bend a spindle, I went and got another spindle, well the spindle that i got brand new from dealer was bent. The dealer order 2 more spindles. they come in and they were bent. I was like what the heck. Finally the dealer got some new spindles that was not bent. Well after 4 spindles. I finally got a decent one.
Also on the SLT 1554 it is best to get some good angle iron and redo the hitch area. The metal there is way to flimsy. If anyone uses this tractor in winter time make sure you can get ag tires or tire chains with some weight. This machine is pathetic in the winter if you don't have this.
I am going to make a phone call to HYDRO-GEAR to get more info on the hydrostaic drive that came with my tractor. www.hydro-gear.com
:confused:
mike
(28) 4' FLOURESENT LIGHT CEILING FIXTURES (A54757)
(28) 4' FLOURESENT...
2017 Ford F-250 Reading Service Truck (A55852)
2017 Ford F-250...
2014 Crossroads Sunset Trail ST33PB14 34ft. T/A Travel Trailer (A55853)
2014 Crossroads...
UNUSED FUTURE MINI EXCAVATOR HYD AUGER (A57193)
UNUSED FUTURE MINI...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
UNUSED FUTURE STB47 141" TELESCOPIC BOOM (A57193)
UNUSED FUTURE...
