Any info on hydraulic valves
   / Any info on hydraulic valves #1
jim98
Have one on my 300 jd and the plow drifts down when I lower it
   / Any info on hydraulic valves #2
Jim98:
I am not quite sure what you mean by "plow drifts down when I lower it". So if you will explain just a little bit more might be able to help solve the problem. If you are saying with the blade is up with the motor off and it lowers itself over time that is kinda normal. If what you are asking if it drifts down while the motor is running then I beleive your lift cyl. is defective and fluid is passing thru the cylinder.
It only happens when engine is running and when I lower the blade and let off the lever the blade slowly goes completely down , I think it may be that my hydraulic valve is bad not sure . I'm going to replace it with one with 3 levers
   / Any info on hydraulic valves #4
Could the problem not be leaky seals in the 3pt cyl?
A couple of seals will cost less than a valve.
You need a good cyl to test the valve.
If you raise the 3pt and shut the engine off, how long does it take for the 3pt to drop to the floor?
Could the problem not be leaky seals in the 3pt cyl? A couple of seals will cost less than a valve. You need a good cyl to test the valve. If you raise the 3pt and shut the engine off, how long does it take for the 3pt to drop to the floor?
it's not the three point it's the power angle snow plow
   / Any info on hydraulic valves #6
With the blade in the air, can you unplug your hoses? :confused3: If you can do that and the blade stays in place, then you know that it is the valve. If it leaks down at an unacceptable rate, then it is the cylinder seals, could still be the valve also, but you know for sure if the cylinder is leaking or not. ;)
   / Any info on hydraulic valves #7
Is the inside lever all the way forward? If it is that is the "float" mode. And it should go all the way down when you stop holding it. Now if the inside lever goes do when you just push it a little way when you let go of the lever it should stay and not drop. Might check to see if by chance you are pushing it to far forward....................KJD
Thanks for the info fellas I'm a dummy I figured it out it's a bad valve lol but thanks
SHOP MADE MANIFOLD TRAILER (A52472)
SHOP MADE MANIFOLD...
Unused Delta Crash...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
2007 Ford Taurus Passenger Car (A51694)
2007 Ford Taurus...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
