Rotary Cutter Any idea what this bush hog is worth?
   / Any idea what this bush hog is worth?
Trust me I know JD does not make them.
   / Any idea what this bush hog is worth? #12
5 and 6 ft. Mowers are very common and can be bought second hand cheaply. 4 ft. and 10 ft. cutters are rare and command a higher price because people that want that size need that size. Either they have a small Yanmar or they do not want to be dragging a 5 ft. mower round in a big field. Odd sizes bring better prices because they are not everywhere you look.
   / Any idea what this bush hog is worth? #13
I'd want to check the gearbox to see if there's any water in it. Clean the deck off and see if there's rust. Then lift it out of that pile of leaves and dirt and see if there's rust on the sides or the runners. Spin the input shaft on the gearbox to see if it turns freely. Look underneath to check the condition of the blades and the underside of the deck. Check the tailwheel to see if it turns and spins, and move it side to side to see if the bearing seems good.
Check the fit of the shearpin in the input shaft. If it's all wallowed out, that could be a sign that it's been heavily used and, possibly, abused.
Check the condition of the PTO shaft to make sure it's not bent or frozen up from rust.
As has been said, just because it's a Deere doesn't mean it's a good one. But it does mean you should be able to source parts for it.
If it was in good shape, I'd give $400 for it.
2012 PETERBILT 367 (A55745)
2012 PETERBILT 367...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
2015 WESTERN STAR  4900 SB (A55745)
2015 WESTERN STAR...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
