Any good explainations of tractor sizes?
   / Any good explainations of tractor sizes? #1
orlo
Platinum Member
Guildhall, VT
JD 2305/JD 4720 cab
Hi:
Does anyone have a link to a good explaination of all tire sizes? For example, on a 3000 series the larger R4's are 43x16x20 in which the 43 makes sense (outside diameter) and the 16 is the width but what is the 20?
Now compared to the smaller R4's that just are listed as 15-19.5 what are these dimensions so that you could compare them?
   / Any good explainations of tractor sizes? #2
43x16x20, 20" wheel/rim. 15x19.5 15in wide 19.5 wheel/rim.
David
Thanks. So the tires that list only two dimensions don't disclose their outside diameter. Makes comparing them kind of difficult... ;(
Bradco SG30  Stump Grinder (A53314)
Bradco SG30 Stump...
2017 Mitsubishi Mirage G4 Sedan (A55758)
2017 Mitsubishi...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
1999 Case International MX200 Tractor (RIDE AND DRIVE) (A50775)
1999 Case...
air compressor (A55758)
air compressor...
High Lift Ratcheting Off Road Utility Farm Jack (A55787)
High Lift...
