CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 5,105
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200
The HT-23 has the Eaton 11 unit fitted and all the aux hydro power comes from the charge pump.
Reading the literature
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@hyd/documents/content/pll_1616.pdf
The aux circuits are depicted as user supplied. In the Hydro description there are statements regarding pressure and flow options from the charge pump to supply the aux systems. The pressure potential appears to be 5-10 times greater than the charge pump internal relief. (which is seen by the fluid filter)
In particular are these informations listed in the "Model 11 Pump" description.
Normal Charge Pump Flow and Pressure
15 L/min [4.0 GPM] at 7,6 bar [110 PSl] and
3600 RPM.
Charge Pump Flow and Pressure Available
to Auxillary Circuit
5,7 l/min [1.5 GPM] 34
bar [500 PSl] (55 bar [800 PSl] optional)
How is the pressure adjusted and how might the "two pressure" requirements be implemented?
TIA for any light you can shed on the subject.
3600 RPM.
