Oil & Fuel any easy way to get gas in the tank?
   / any easy way to get gas in the tank? #31
LB is missing a great opportunity to show the OP his setup. 30 posts and no LB, starting to worry about him!
   / any easy way to get gas in the tank? #32
Should we send someone to his house?
Perhaps he's trying to exercise his herd?
   / any easy way to get gas in the tank? #34
I turned it upside down when I drilled the hole.
You sound like my dentist. LOL. If you don't have a drill, heat up the tip of an awl, aim, and poke. Insert a golf tee, and apply for your patent.
   / any easy way to get gas in the tank? #35
:D:D:D HEE HEE HEE . I agree. now we see he went to a wedding. ;)
   / any easy way to get gas in the tank? #36
Is there an easy way to lift a heavy 5 gallon diesel jug up to fill the gas tank? Any way to prevent spillage? I'm about to fill up my MF 1531 for the first time.
Thanks alot.
ymarianne
We make of fun LBrown, but he does have a nice setup. And since you're dealing with diesel you might want to search on fuel diesel and posts by LBrown. Even if you're only dealing with small set up.. I found out I can get 15 and 30 gal containers for free from my local car wash. I just have to be there when he is there.
Wedge
   / any easy way to get gas in the tank? #37
Here is my solution. 12V fuel pump and auto shut off nozzle from NT. To power it I added 12V outlet to the back of the tractor (Also used for three point sprayer). I did that to impress my wife. I could get by with a rotary hand pump.
   / any easy way to get gas in the tank? #38
If you can walk naked out of your house and p@e from your front steps then you can claim that you don't live just on an acreage but you live in the country.
Hey I can do this.. Or mow the yard naked. :D
Wedge
   / any easy way to get gas in the tank? #39
Wedge
I could do that to but with my little lot I would be whizzing on the neighbors property now or just give them all a good laugh :D
   / any easy way to get gas in the tank? #40
Wedge
Why my wife has no tan lines? She does the mowing.
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
CATERPILLAR...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
12ft X 16ft Storage Shed (A55853)
12ft X 16ft...
2000 INTERNATIONAL 4900 CAR HAULER (A57880)
2000 INTERNATIONAL...
2013 Ford Escape 4WD SUV (A55853)
2013 Ford Escape...
