Anuther lektwonix kwestyun
   / Anuther lektwonix kwestyun #1
MChalkley
Elite Member
Eastern Virginia
EarthForce EF-5 mini-TLB (2001)
I'm on a real "take more than I'm giving" roll on TBN lately, so in the interest of continuing that trend, and futhering the visibility/safety of my flashers on my EF-5, I'd like to ask the resident electronics gurus (Al, are you out there?) another question.
I mentioned in the thread on strobes that Bob started that Whelen has a "pulser" module for flashers. I'm not exactly sure what it does, but I suspect it produces 3 or 4 flashes a little longer than the "persistence of vision" duration (what is that, 1/23 of a second or so? I forget...), interspersed by off cycles of about the same duration, followed by the balance of the 2-second-or-so on cycle, followed by a 1 second or so off cycle, then the whole thing repeats.
Obviously, you can't do this with an incandescent bulb, because they aren't fast enough. My question is: How tricky is it to design a circuit to do this? And how much would the parts cost? Ok, that's two questions, but you guys have never been strict on that before...
   / Anuther lektwonix kwestyun #2
Mark,
<font color=blue>Al, are you out there?</font color=blue>
Well, just barely. I'm about ready to fall asleep waiting for 100K. Most strobes use a xenon tube and a trigger transformer to discharge a high voltage capacitor (300-400v) into the tube. Just like the flash on your camera, just runs periodically. I have built several when the kids were into launching rockets. Circuitry is simple and you can buy kits, Edmund Scientific and others for less than $20. I don't know anything about a "whalen".
Al
Whelen makes a lot of lights for emergency vehicles. But one of their options, and I don't know what they charge for it, is a pulser-flasher like I described that works with any kind of LED light. It's not a strobe, but it generates a strobe effect, just by pulsing the output to the LED. At least, that's what I think it does, based on a description I saw somewhere on their web site.
   / Anuther lektwonix kwestyun #4
<A target="_blank" HREF=http://strobeguy.safeshopper.com/specials.htm?210>Strobes & More...</A>
Flash 3 Headlight flasher
Product Details Stock #: Flash 3
The FLASH-3 does a standard back and forth wig-wag type pattern at a rate of 3 flashes per second.
Special: $35.99
Mark,
Here's something that may work with your nicely designed and existing rear light array...
{and you can still add some Whelen strobes...}
   / Anuther lektwonix kwestyun #5
Mark,
If all you want to do is pulse your LED lights in a strobe fashion that is no big deal for just LED's, but I think you mentioned that they had some other stuff in the light which allowed a constant illumination across a broad voltage range. In that case it may not be quite so simple. I have built a fish finder the mimics the operation of the old style neon light rotating on a motor. In that application to get a reasonable amount of light output I pulsed the LED's at 5 times the rated current but a very low duty cycle.
Al
   / Anuther lektwonix kwestyun #6
I'm guessing the fancier ones have an IC in there to control the timing also. If I remember my personal ancient history there may be a few calculations necessary to get the right capacitor for the circuit - otherwise you won't get flashes of uniform brightness on the strobe - i.e. need to take into account how quickly the circuit charges before you can discharge it again.
A bit more trickery with the IC and dip switches would allow you to control how many pulses in a group and the time between groups.
My electronics knowledge is dusty though. Best bet is a local enthusiast that has a permanently warm soldering iron. Components would be cheap - it's just a niche application.
Patrick
   / Anuther lektwonix kwestyun #7
RPM,
<font color=blue>Best bet is a local enthusiast that has a permanently warm soldering iron. </font color=blue>
Well put, and sound advise /w3tcompact/icons/smile.gif
Al
Twinkle_Toes - Hmm. /w3tcompact/icons/hmm.gif You're right - I had forgotten about the internal circuitry. All it is though, is a power supply circuit. It ensures constant voltage at to the LEDs, as long as the input voltage is between 8 and 32 volts. So it shouldn't be affected by pulsing the input voltage, as long as it was a "digital", or square wave pulse, right?
   / Anuther lektwonix kwestyun #9
Mark,
<font color=blue>So it shouldn't be affected by pulsing the input voltage, as long as it was a "digital", or square wave pulse, right? </font color=blue>
That should be right, so long as the supply has no energy storage (capacitors) of consequence. Give it a try by touching the hot lead to the battery lead and see if the LED illumination follows the contact bounce.
Al
Al - It appears to, but I'm not exactly sure what I'm looking for. When I was messing with them earlier to take the pictures, they snap right on, and if you scratch the lead across the terminal, they flicker very quickly.
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52128)
2019 Energreen EVO...
(1) 24' CORRAL PANELS W/ (1) 8' GATE (A51243)
(1) 24' CORRAL...
FORD 7600 TRACTOR (A51243)
FORD 7600 TRACTOR...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
SET OF (4) TITAN MULTI TRAC C/S TIRES & WHEELS (A51244)
SET OF (4) TITAN...
