Antonio Carraro with a hoe/blade.
   / Antonio Carraro with a hoe/blade. #1
Tunin
Medjugorje
B2410 Kubota, Antonio Carraro SRH9800 and SRX8400
I finally adopted my Antonio Carraro to the Clemens under-stock hoe blade (or the other way around :)). I only bought the red part, used for 350 euros. The lift and everything else is what I mocked up. The ready and done from Clemens is crazy expensive, what I built for a 100 euros of materials, would have cost me 3500 used from Clemens Original.
Added a generic solenoid valve to divert the fluid if needed if the antenna sensor does/can not do in for whatever reason…
Once I get it going, will make some videos using it, in the meantime, here are some videos I did before, when I adopted it to my Kubota B2410 years back.
At first it did not seam to be doing much but one comes after A day, the weed is all dried up and the soil is quit crumbly and soft.
   / Antonio Carraro with a hoe/blade. #3
Great job! It's doing a very nice job.
Nice tractor as well!
   / Antonio Carraro with a hoe/blade. #4
Nice but I wish I understood it's operation. Is there only 1 "disc" that engages the soil? It looks like it's very adjustable.
Thanks for posting 👍
Thank you. Yeah, model SRH9800, hydrostatic. Very versatle, narrow, as narrow is neaded for our old Mediterranean patches of vineyards and olive orchards, very nimble ( I hope that is the Eng. word) :)
The disc only cuts a grove for the blade leg to go through, the blade with the tails does the job, it cuts underneath, depth adjustable, the tails move the soil and weed. It comes quite close to the trees, the soil gets worked quite well.
Let me try and find a photo from a few years ago, what it looks like a day later…
   / Antonio Carraro with a hoe/blade. #7
I totally agree. I have a couple orchards and could use a lower and narrow tractor. Ended up getting just a narrow tractor which is a bit too tall but I still make it work.
I almost ended up with a smaller Tigre 3800 but unfortunately the dealer wasn't too interested on even walk to the yard to show the machine. It would fit my orchard needs very well.
I could not find a photo of a day later but this is what it looks like right after I go through if the middle section is not pre-tilled.
When I got mine a friend got a SRX8400 no cab version, very low otherwise similar capabilities. Here are some photo them both together and one of mine for last years harvest.
I started a thread about a dealer in the US! east coast, that deserved a credit.
AutrUSA
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
2004 MACK CX VISION (INOPERABLE) (A52472)
2004 MACK CX...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
