Antiroll Device for TN
   / Antiroll Device for TN
Sure is.
Called them up and it turns out a local guy stocks long shank 2 5/16 balls! Got one today.
It would still be nice to have an antiroll device. May need to breakdown and build one. Attached shows why the ones you usually see won't work.
The arms of this 3-point are ajustable. You pull the pin and the ends can pop out > 4" inches and move up and down a bit. Sure makes hookup of implements a joy. But that part of the arm is large both in vertical and horizontal dimensions. No way one of the antiroll devices will clear. The thick part of the arm gets in the way.
Also in the pic is the drawbar. Looks small in this picture but its substantial.
Fred
   / Antiroll Device for TN #12
Of course I've seen lots of telescoping lower links, but don't think I've ever seen, or noticed, any with the pin like that before.
   / Antiroll Device for TN #13
The small pull pin in the picture is attached to a larger block so that it doesn't snap off with the stress from the implement. The block is the size of the cup on the top of the arm and is quite heavy.
Robert,
Thanks for clarifying. Yes the pin is just to give you something to pull on. It dioes not pull out like a link pin, but is spring loaded to release the internal locking mechanism.
The locking mechanism is very strong, not just a small pin.
Fred
   / Antiroll Device for TN #15
No problem. I had to tear mine apart once because it seized up and remember quite well what it looked like /forums/images/graemlins/smile.gif Take care.
2014 Lamar Trailers 45ft T/A Pipe Handling Trailer (A55973)
2014 Lamar...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
