Tires Antifreeze/Water solution to fill Tires?
   / Antifreeze/Water solution to fill Tires? #11
They're gorgeous dogs, Pete!
   / Antifreeze/Water solution to fill Tires? #12
Thanks! They're spoiled, too! /w3tcompact/icons/laugh.gif
Pete
   / Antifreeze/Water solution to fill Tires? #13
Windshield Washer is Poisonous. It says on the bottle can cause blindness. I don't think any of these liquids that are made to not freeze, are good if swallowed. I hope never to have to worry about leakage. Also looked at cost, and whether it was likely that it would rust my wheels. Many people have used this stuff for those reasons.
   / Antifreeze/Water solution to fill Tires? #14
Boondox:
It looks like your boys did a good job splitting all that wood.
   / Antifreeze/Water solution to fill Tires? #15
What size tire did you get the 15 gal. into?
My 15 - 19.5 R-4's took 30 gal. each when I filled them with Windshield Washer fluid. Figured roughly 250# each tire.
   / Antifreeze/Water solution to fill Tires? #16
12-16.5 R4's for my TC21D. I figured 15 gallons in each to be about 150-160 LBs. Sound right?
   / Antifreeze/Water solution to fill Tires? #17
Probably need to figure 8# per gallon, as it will be close to the weight of water. Maybe around 120# per tire.
   / Antifreeze/Water solution to fill Tires? #18
Beenthere, You're probably right, I did figure it that way, but my cousin the tireman said more like 150#. Either way it helps a lot for loader work. Kent
   / Antifreeze/Water solution to fill Tires? #19
Thank you, Pete. Goldens are my favorites. /w3tcompact/icons/smile.gif
   / Antifreeze/Water solution to fill Tires? #20
I notice them 3 in front of the wood pile lookin like they helped, did they stack it, or do they fetch it into the house for you?
My hunch is they lay in front of the stove and watch you carry the wood in.
New/Unused (1) Pallet of Ground Protection Mats (A54865)
New/Unused (1)...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A55745)
2015 DRAGON 130...
1R SILT FENCE PLOW (A52706)
1R SILT FENCE PLOW...
